B-8-D
down to one car!!
Jun 27, 2007 11:11:34 GMT
I am selling my sc14 supercharger as I'm skint!! its 2 lobe rootes type positive displacement supercharger and passes 1420cc per revoloution.. it has an electric clutch so can be switched on and off by a switch.. exellent working order.. good for many convertions as there is no adaptors to make just fit tubes intacke and outlet.. good for any engine between 1400 and 4000cc. £250....ono[glow=red,2,300][/glow] here is a picture of me fitting it in my old cortina.. 1/2 a day and it was done!! bodgetastic!!
Last Edit: Jun 27, 2007 13:10:06 GMT by B-8-D
Jun 27, 2007 11:25:58 GMT
pm sent
Jun 27, 2007 11:27:28 GMT
how big is the supercharger?? size wise and does it have an oil feed to lube it and a drain back to the sump? andy
B-8-D
down to one car!!
Jun 27, 2007 11:36:02 GMT
it has ist own oil supply and dipstick.. so no external supply needed.. si
Jun 27, 2007 11:41:15 GMT
dimentions like is it 12" long 6"wide I'm just thinking if it will fit were i want it to go also does it mount like you mount a alternator ?? (sorry for all the questions pointless shelling out if cant use it ) andy
B-8-D
down to one car!!
Jun 27, 2007 11:43:57 GMT
diamentions are: overall length from front of the pully to the rear of casing is 300mm or 12" hight is 250mm or 10" to the outside of the mounting lugs.. and width is 130mm or 5" from intake to outlet face including the manifolds fitted it is 240mm or 9 1/2" overall. si yes it mounts like an alternator i.e. it has two top lugs inline on the bottom and two inline on the top.. that a 10mm bolt/bar can be passed through. si
Last Edit: Jun 27, 2007 11:48:29 GMT by B-8-D
Jun 27, 2007 13:41:00 GMT
what toyota engine is this off??
B-8-D
down to one car!!
Jun 27, 2007 13:54:38 GMT
what toyota engine is this off?? its from a 1G-GZE 2l strait six. i brought it back from australia.. si
Jun 27, 2007 16:32:28 GMT
might be interested in this. all depends if someone wants my intercooler
Jun 27, 2007 20:31:27 GMT
does the supercharger need servicing like a g40 or g60 charger does?
would this be any better than my eaton m45 charger i have now. would it suit my polo g40
B-8-D
down to one car!!
Jun 27, 2007 22:20:36 GMT
does the supercharger need servicing like a g40 or g60 charger does? would this be any better than my eaton m45 charger I have now. would it suit my polo g40 don't quote me on this but I think its a little bigger than the m45 so will suit a bigger engine.. ive heard that the m45 is stretched on a 2l engine.. I wouldent say its any better though.... but don't eatons have a tendency to self destruct if revved too hard?? I could be wrong they all have a rev limit! o and servicing wise its just to change the gear oil every now and then.... si
Last Edit: Jun 27, 2007 22:21:56 GMT by B-8-D
my engine is a 1308cc superchargered polo engine currently running around 230bhp with the eaton. what will your supercharger let it rev to as my engine does rev quite high.
the eaton was off a bigger engine anyway. the reason I'm looking at yours is to between it has a switch for on and off as I'm putting a turbo on the polo also which will come in when the sc goes out. bit if your charger is sufficient it might be worth just using that.
how old is it btw. what year car is it off
B-8-D
down to one car!!
lots of maybe's but not sold yet..... anyone?? si
bstardchild
Club RR Member Number: 71
lots of maybe's but not sold yet..... anyone?? si If I hadn't gone down the carb route I think I'd have been another maybe...... It's an unusual thing for sure
bstardchild
it has an electric clutch so can be switched on and off by a switch.. Can air still be drawn thro a rootes type blower when it's not rotating?
B-8-D
down to one car!!
