ill add some due links due to mass of parts loads of 60/70s vw beetle parts
www.volkszone.com/VZi/showthread.php?t=350633&page=1
type3 /bug complete lock set and out door handles with key and coloum storks
complete 924 porshce dash speedo/revcounter ,fuel/temp etc
porsjce 911 complete fuse box
911 gearstick boot
911 heater control
911 seat belt holders
911 tray fits infront of gearstick /black
pair of rear 74 bug wings
pair of front fibre upright wings 2inch wider
landrover 2.5 td engine spares due to engine haveing a knackerd crank
injector pump
water pump/vac pump
engine block /head/injectors/flywheel
oil pipes
turbo has internal play thow
vauxhall omega dash switchers
omega alti
starter
complete 2.5 clyinder heads vauxhall v6/bottom end
vauxhall td caliver starter
vauxhall alti and vac pump
peogout vacum belt pumps/starters
golf mk2 front discs and pads were new have surface rust
golf front struct bar
golf td alti
1.4 foucus 1.4 water pump
1.4 rocker cover
1.4 injection system/inlet manifold/injectors/idio control valve
1.4 flywheel
1.4 clutch
ford mondeo td alti
volvo 850 mreg spares
ecu cover
plasic boost pipe
tdo4 turbo unit
power steering pump
5 none turbo plugs as new bought in error for volvo
911 gearstick boot
911 heater control
injector pump
water pump/vac pump
oil pipes
omega alti
starter
golf td alti
1.4 rocker cover
1.4 flywheel
1.4 clutch
ford mondeo td alti
ecu cover
plasic boost pipe
tdo4 turbo unit
power steering pump
