Hey folks,
I have kicking round in the garage doing nothing, 3 KP Starlet bugeye tail lights that should probably go to a better home as I initially intended to put them into my car, but now prefer the look of the later units. Will fit both bugeye KP's and flat front KP's with no modification, even the plugs fit and work. I understand these are relatively sought after offshore, so thought I'd try my luck!
In good condition, bar one which has a slight crack in the reverse lens (the same side which has the double up so you end up with a good pair) and there is some paint overspray on 2 of them from a previous owner, which should remove easily with some prepsol or plastic polish.
Offers thanks, I will ship o/s if need be although having never done this before please bear with me if it does happen.
Thanks,
Richard
Thanks,
Richard
