Mr K
This was a thread asking for a brake bias valve, but its now a thread asking for lots and lots of bits for Project Kitty.
what I need is: - Brake bias Valve
- 6 x nuts for seatbelt bolts - cant find them anywhere
- fiat punto sporting mk2 1.2 16V flywheel
- Fiat punto sporting mk1 1.2 16v ECU, bottom section of manifold + injectors, and fuel rail, all engine sensors, crank pulley, exhaust manifold, coil packs + other ignition bits, starter motor, and ignition/injection loom(its seperate to the rest of the cars loom)
- Bucket seats; these need to be pretty narrow, and either black or brown, and preferably retro; no need for them to be in date
- 4 point harnesses, also no need to be in date but must be black/brown and cool
- 12" mountney or simular - fiesta mk1 calipers
- suzuki SJ413 jeep clutch disc and release bearing
- 10mm ID thick walled tube, about 1' of it, to be wleded in to reinforce/ stop it collapseing where I have made holes for trailing arms through chassis rails.
- Monster Tach or simular
- 2 x small motorbike rear coil overs
- low pressure fuel pump
- high pressure fuel pump
- twin downdraugh carbs (36s or somthing nice n little)
- fire extinguisher kit
- fibregalss battery box
so what you got in ya garage? obviously I cant afford to buy all that lot in one go right now, nor do I need it all right away, but I am just having a look about, and trying to get a few bits crossed off my list as knowing who has them / where I can get them and how much.
I will keep this upto date as I find I need more bits / get bits.
Ta,
Nick
Last Edit: Dec 18, 2006 19:42:17 GMT by Mr K
Mr K
Dec 18, 2006 19:42:55 GMT
Bumpety Bump
slater
Club RR Member Number: 78
WTD: bits for pReject kitty. slater
@slater
Club Retro Rides Member 78
Dec 18, 2006 19:51:01 GMT
Can get you a brake bias valve from work quite easly. They are just pneumatic regulators. Not till the new year now tho of course.
Can probably find you some fiesta calipers that would need a rebuild (vented xr2 or non-vented 1.1?)
Seatbelt nuts? you mean 7/16 unf nuts yes? can probably find some of them too.
Mr K
Dec 18, 2006 19:58:13 GMT
sounds spot on - how much we talking? I'm in no rush
solid 1.1 discs. could you hang on ot them a while if you hav any, as I want to get my discs re drilled and check thats all O.K. first (probably late jan/feb)?
yup, thats the ones, havent got out to the local nut and bolt shop yet, but if you have some you could send with the bias valve it would save alot of hassel.
Cheers
Last Edit: Dec 18, 2006 19:59:05 GMT by Mr K
bigvee
Dec 18, 2006 20:48:23 GMT
Got a rev counter for sale I'm in hants to if you want a look
Mr K
Dec 18, 2006 20:55:10 GMT
Got a rev counter for sale I'm in hants to if you want a look what kinda rev counter we talkin here? I'm realy after one with a shift light n all that.
bigvee
Dec 18, 2006 20:56:35 GMT
Yep shift light and all that I'm north of Soton if you want a look
Mr K
Dec 18, 2006 21:05:32 GMT
cool, I'm in between alton and petersfield.
any pics? I'm pretty busy so don't know when i could come for a look; you in a rush to get rid of it?
bigvee
Dec 18, 2006 21:06:55 GMT
No rush, no pic at the mo I'll try to sort one out
Dec 19, 2006 12:52:02 GMT
When my 510 goes back on the road, I'll be fitting some new, modern race seats. The ones in it now are old school black vinyl fixed buckets with slots for four points. I'd sell them for £75 for the pair and I might even have some old four points I can throw in for free (maybe...I'll have a look in the shed). Here's what they look like... ![](http://img.photobucket.com/albums/v651/ratdat/510/0910_0159.jpg) -Ed
Mr K
Dec 19, 2006 13:06:13 GMT
When my 510 goes back on the road, I'll be fitting some new, modern race seats. The ones in it now are old school black vinyl fixed buckets with slots for four points. I'd sell them for £75 for the pair and I might even have some old four points I can throw in for free (maybe...I'll have a look in the shed). Here's what they look like... ![](http://img.photobucket.com/albums/v651/ratdat/510/0910_0159.jpg) -Ed I LOVE THEM! ill take them! one thing, how wide are they? as i done have tooo much room. ta
Dec 19, 2006 13:13:23 GMT
They are very narrow as they were previously in a Mini and even the 510 is a narrow car. You can see how much room there is between them in the pic. if you want I'll measure them just to be sure they'll fit.
Mr K
Dec 19, 2006 13:23:08 GMT
They are very narrow as they were previously in a Mini and even the 510 is a narrow car. You can see how much room there is between them in the pic. if you want I'll measure them just to be sure they'll fit. well, I'm not entirly sure how much room i have until i get the body back on, and that wont be for ages, so ill just have to cross my fingers, but they are EXACTLY what i was looking for! ill probably be in contact around feb time? that be ok? and certainly don't sell them to anyone else! ;D
Dec 19, 2006 15:58:19 GMT
I won't begin doing anything with my 510 until around then so that's fine by me.
Dec 20, 2006 22:21:49 GMT
No they are not. Please, please don't try this at home kids.
Dec 21, 2006 23:50:00 GMT
I didnt think that a pneumatic regulator would take brake fluid at 3000psi?
tigran
In rust we trust. Amen.
Club RR Member Number: 142
WTD: bits for pReject kitty. tigran
@tigran
Club Retro Rides Member 142
street
6.2 ft/lbs of talk
Dec 22, 2006 16:32:25 GMT
I think I have a brake bias valve from a Fiat Uno, i'll have a look for it ![;)](//storage.proboards.com/forum/images/smiley/wink.png)
Dec 22, 2006 17:21:13 GMT
Its possible to get a pneumatic or hydraulic regulator that will handle the pressure they are more specialist though and price wise they work out almost the same as a normal brake bias valve. But normally the seals don't like brake fluid. I have some at work that are rated to 4000 bar but those are rather expensive. ![;)](//storage.proboards.com/forum/images/smiley/wink.png)
Dec 22, 2006 20:33:14 GMT
I posted my reply, because a simple comment like you can use a pneumatic regulator as a brake bias valve, can soon become common knowledge because it's on the internet. If it was a highly specialised, expensive piece of kit, not a real problem, but a lot of people have old regulators kicking around the garage from welding sets or compressors. Now you have 'cheap mod' that you can do in a couple of hours that will start to circulate on every car forum out there. A pneumatic regulator is just that...a PNEUMATIC regulator. All the orifices, valve seats etc are designed for the CV of air or gas. Air is compressible, fluid isn't - the regulator will have been designed with this variable factored in. There a many types of regulator - relieving/non-relieving, pilot operated etc etc. A pneumatic regulator is an inherently more complicated device than a brake bias valve and as such will have a completely different failure mode to a brake bias valve. Will it fail safe? You could argue even a catastrophic failure on a regulator in a rear brake circuit (of a front/rear split system) will just leave you with no rear brakes and the fronts will stop you OK, so in theory this isn't single point failure. ![;)](//storage.proboards.com/forum/images/smiley/wink.png) The wetted surfaces will not be designed for brake fluid. Most will have elasotomeric seals - not all are going to be compatible with brake fluid. Sure there are plenty of pneumatic regulators designed to cope with >3000psi ( in fact most bottle reg's should) but this isn't the point - will your average punter know the difference? So again, please don't use a pneumatic regulator as brake bias valve. After all, a proper brake bias valve is not that much. Sorry to thread jack but safety first and all that.... ![::)](//storage.proboards.com/forum/images/smiley/eyesroll.png) Back on topic, sorry don't have any parts I can help with, but I do have a Mk1 Punto as a daily hack, so if you need any pointers or photos of where all the tubes and wires plug in, let me know.
