Not mine - a post just in case anyone else is interested!
"sprint shell and suspension and brakes, rover v8 fitted, needs prop and exhaulst and putting back together. loadsa new bits like suspension bushes and adjustable struts, stainless steel sprint/1850 sports exhaulst and 14inch minilight replicas, plus other spares £300 the lot, west susssex"
From a member who went to view it :
"shell is pretty tidy structure wise, rear doors are shot underneath, skins are good though. front doors ok. bonnet not fitted and I don't think it would fit. roof linig trashed when the rear windscreen was removed. No door furniture, incomplete set of window glass - not fitted.
White shell with black overspray on it, wants a good clean and then maybe a touchin.
Needs a water pump sourcing, starter motor (not sure if that is there - it may be) needs exhaust manifold making up, and a prop. radiator not fitted, maybe present but doesn't look like it. engine looks complete, but the heads are off etc. seats are non sprint - maybe opel manta?
Sump needs cutting and shutting, clutch adjustments done to make it work inside the car. engine mounts made up for sprint subframe, mods to that look complete
minilites and other details as described in ad.
would need to be stored undercover "
Sounds like a lot of work but could be a good winter thing for someone
PM me and I'll get you contact details.
