...one set of (four) original Nissan Bluebird wheel trims (Ithink from a circa 1987 car). Not broken or cracked but a couple could do with a quick blast of spray. £10 the set plus postage or you can collect.
i12.photobucket.com/albums/a249/Cavmad/jag/bxgtiecuetc006.jpg
1 x 185-65-15 Keleber tyre. Loads of tread (approx 6mm) and not on a wheel. £10.
i12.photobucket.com/albums/a249/Cavmad/jag/bxgtiecuetc001.jpg
1 x 185-70-14 Bravura tyre currently fitted on 4 stud Vauxhall steel wheel. Loads of tread, ready to fit. £10.
i12.photobucket.com/albums/a249/Cavmad/jag/bxgtiecuetc002.jpg
1 x 205-65-15 Michelin on 5 stud Vauxhall (Omega) steel wheel. Approximately 4mm of tread. £8.00.
i12.photobucket.com/albums/a249/Cavmad/jag/bxgtiecuetc004.jpg
1 x 205-60-15 (will need to check make) tyre on 5 stud 5 spoke Vauxhall Vectra SRi alloy wheel. Tyre and wheel in good order but wheel will need quick blast with wire brush around inner lip to seal better. £15.
i12.photobucket.com/albums/a249/Cavmad/jag/bxgtiecuetc008.jpg
1 x 14" Vauxhall alloy (as fitted to late model Ecotec Cav`s). Wheel average, tyre seems u/s but wheel good for a spare. £6.00
i12.photobucket.com/albums/a249/Cavmad/jag/bxgtiecuetc003.jpg
Mondeo estate roof spoiler, white, in excellent condition. £20.
i12.photobucket.com/albums/a249/Cavmad/jag/bxgtiecuetc005.jpg
BMW 7 series both sets of twin headlights (from approximately 1989 car). All working and will include the plastic surrounds etc if I can find them. Posible cheap way of making your own twin headlight conversion. £250 per side PLUS VAT from BMW!
£25 the lot.
Various Honda CB250N Superdream spares, namely coil and leads,rear shocks, chain guard, front caliper, front Comstar alloy wheel with near new tyre and possibly some other smaller bits too.
i12.photobucket.com/albums/a249/Cavmad/jag/bxgtiecuetc009.jpg
i12.photobucket.com/albums/a249/Cavmad/jag/bxgtiecuetc010.jpg
i12.photobucket.com/albums/a249/Cavmad/jag/bxgtiecuetc011.jpg
Collection welcome, could post stuff out at cost if required. All near Chester, Cheshire and very close to M53/A55 and M56 and M6 nearby too.
£25 the lot.
