street
6.2 ft/lbs of talk
Sept 29, 2006 14:06:02 GMT
As title really! Must be the mk3 Diesel, I believe the mk4 mounts are different In good working condition obviously Check your garages, sheds, down the back of the sofa, pockets of a coat you havent worn for ages etc!
street
6.2 ft/lbs of talk
Sept 29, 2006 19:48:15 GMT
Yeah they did them, I'm guessing there will be more dead mk3 vans or combi's with a diesel lying around than the hatch though! Would like a LSD box but I cant really afford it at the moment, a diesel box will do for now You've just reminded me of something.... PM'd you
street
6.2 ft/lbs of talk
Sept 29, 2006 20:16:25 GMT
I want the longer ratios I've heard that they are stronger but its the ratios i'm interested in.
Sept 29, 2006 20:19:52 GMT
Is the Mk2 Fezza diesel the same? Might broaden your options a bit?
street
6.2 ft/lbs of talk
Sept 29, 2006 21:08:00 GMT
Aah good advice Graham, cheers! Is the Mk2 Fezza diesel the same? Might broaden your options a bit? I'm not sure if the mk2 fez has the same box.... I reckon it might, good thinking! I'll find out for sure if its the same or not
Last Edit: Sept 29, 2006 21:09:05 GMT by street
hitman
Sept 29, 2006 22:15:47 GMT
Aah good advice Graham, cheers! Is the Mk2 Fezza diesel the same? Might broaden your options a bit? I'm not sure if the mk2 fez has the same box.... I reckon it might, good thinking! I'll find out for sure if its the same or not the mk2 fiesta box wont fit pal(same setup as mk4 escort)and pretty sure mk3 escort turbo didnt have lsd
madmart
love is: valvebounce in top gear
Sept 30, 2006 3:41:27 GMT
hi escort mk5/6 box is the same as a mk3 mounts wise the fez and mk4 are diffrent
street
6.2 ft/lbs of talk
Sept 30, 2006 10:10:13 GMT
Cheers for the info guys ;D Hitman- looks like a fez box is out of the question then I think the series 1 does have LSD, 99% sure anyway! Madmart, does the mk5/6 have the starter motor on the right side do you know? If so theres probably tons of them in the scrappy so that will be ideal!
Last Edit: Sept 30, 2006 10:11:31 GMT by street
Sept 30, 2006 15:40:43 GMT
mk5 box will fit just make sure you get one with the starter at the front & the mk1 turbo box did have an lsd
find me on facebook to see photos of things I'm selling off !!! All Forshow or ebay all-4-show-uk
madmart
yep u need a mk5/6 box with the starter at the front, theres loads in most breakers
street
6.2 ft/lbs of talk
Cheers guys, finding one shouldn't be a problem then!
