Mike
East Midlands
May 15, 2006 17:09:50 GMT
Changed me mind on this one, but i guess we all do that. Its a multi fit roof rack, adjusts a lot on the width and also has 3 height settings. Currently on my Golf, but would fit as small as a Mini (i think) and can probably adjust to nearly half a metre wider. Steel sides and brackets, and ali bars across. I've given it a quick flash over in silver to neaten it up. Ideally i'd like £25 for it. I guess you'd have to come pick it up really, might be a curse word to post. ![](http://i40.photobucket.com/albums/e241/Mykal7655/DSCF0139.jpg)
May 15, 2006 17:14:38 GMT
That'd be pretty cool on the front of my van I rekon, I could stick a board on there and put chairs up, for those chair on a van roof moments....
The lurker formerly known as Cappuccinocruiser.. or wedgedout..
Mike
East Midlands
May 15, 2006 18:16:38 GMT
I'll have a measure of it, and see what the max width is.
May 16, 2006 10:57:15 GMT
If you don't mind chap.
slater
Club RR Member Number: 78
FS: Roof Rack - £25slater
@slater
Club Retro Rides Member 78
May 17, 2006 21:17:07 GMT
If you could post it id be interested. (can you dismatle it?) Its exactly what I'm looking for!
Mike
East Midlands
May 18, 2006 12:28:53 GMT
To answer a couple of questions:
Overall size of the actual "load area" is 1 metre x 1 metre. Full extension width (safely) is 145cm to the edge of brackets (which would be the gutter edge on your roof).
I think it will dismantle Slater, you can see in the photo pretty much how its held together. Its not too heavy, so it might not be too hard to post.
May 18, 2006 15:03:43 GMT
To be fair, if Slater wants it and it's "just what he's been after". I'd rather he has it, I'm only looking at is as an amusing addition.
slater
@slater
Cool, well find out how much i will be to post and il take it! (shouldent be more than £10 ![:)](//storage.proboards.com/forum/images/smiley/smiley.png) )
Mike
East Midlands
May 20, 2006 14:14:02 GMT
Ok, if that suits you both (it might not have quite been wide enough for your wedge Cap) i'll consider it sold to Slater. I'll more than likely be down in the Stowmarket area in a couple of weeks if it easier for me to bring it there, and you can pick it up if you like? Saves you some cash. Not surehow far that is from you... Let me know.
slater
@slater
May 20, 2006 16:09:09 GMT
That would be fine. Stowmarket is only about 30mins from me. keep me posted ![:)](//storage.proboards.com/forum/images/smiley/smiley.png)
