The turbo system is up for sale
This is one custom turbo system for the hillman imp or can be adapted to any car. For £300 i will include the turbocharger which is a garett VNT15 ball bearing unit, with less than 1000miles from new. An external wastegate which was purchased at the same time as the turbo, and the link pipe that will fit on to a janspeed medium bore manifold (1.75" i think)
The carb is a 1.75" montego turbo unit that has been fully rebuilt with a new spindle, butterfly, seals and gaskets, jet, needle, and float valve. The manifold is a custom 930 unit that has be adapted for the carb, there is also the regulator to maintain fuel pressure
The intercooler is a german made unit for the montego turbo, and all of the associated pipe work to and from turbo and intercooler.
For £450 i will include a microdynamics EMS 6 ignition controller and pressure sensor, this enables the turbo system to be used on stock compression with more boost. A hillman imp dizzy with newtronic optical ignition system, again with very few miles on.
A lot of hard work went into this system and it will almost bolt straight into a hillman imp. New fuel lines will have to be laid and a high pressure pump installed, also a few brackets need to be fabricated and the oil drain line installed.
please contact 07881422156
or email giant_killa_blob@hotmail.com
Or PM me
Cheers guys
J
Or PM me
Cheers guys
J
