Polo G40 engine: Spec: BUilt BY RACE POWER MOTORSPORT
1308cc overbore using Karl Schmitt Pistons.
Total Seal Competition Piston Rings.
Flat Planed Crankshaft.
Fully Lightened and Balanced Crank, Flywheel, Rods and Pistons.
ARP Bolts.
Built to a tolerance of 0.002.
Compression 9:1.
Big Valve Race Head. 1mm larger inlet valves, 4.3mm larger Exhaust valves.
Solid Lifters (shimmed to camshaft).
Custom Spec Newman Camshaft.
Uprated Double Valve Springs.
Can rev to 8500rpm.
£offers.
ARP Bolts.
Compression 9:1.
Can rev to 8500rpm.
£offers.
