Slight Change of plans means I have a set of R1 Throttle bodies for sale, complete with loom, injectors, fuel rail, Fast idle (Choke) mechanism, TPS, etc Bore I believe is 40 or 41mm, will check later and take some pics. Ideal for anyone considering Megasquirt or similar Would take a set of R6 Carbs in PX Otherwise £70+ postage ;D Cheers Dom
Last Edit: Jan 9, 2006 0:47:54 GMT by CR500Dom
filmidget
East Midlands
Mostly Lurking
Would you have an idea of bore spacing on those please?
'79 MG Midget 1500 - Still patiently awaiting attention '02 Vauxhall Astra 1.8 Elegance(!) - Better than you might think '03 Mazda MX5 - All new and shiny looking (thanks to Antony at Rust Republic) '09 Renault Clio - Needs to go.
Nick
how much would postage be and where are you located. and i want these.
this weeks car count "5"
Bore spacing I will measure tonight for you
Postage should be about £10-15 I would think ?
I`ll send it the cheapest way possible or however you want I am in Essex though will shortly be working up Near Warwick if thats any better ;D
I`ll post some pics up when I get in as well
Cheers Dom
Pics.... just because I have taken them now ;D Looking side on to TP Sensor Orange things are the injectors Airbox/filter side See the Silver cylinder with the 2 Zinc plated pipes coming out of it ? Thats the automatic fast idle, just plumb the heater circuit to thos pipes and when the engine warms the wax stat inside opens returning idle to standard ;D Kind of like an Auto choke for injection Bore size is 40mm downstream of Throttles Bore Spacing is 82mm 75mm 82mm Sold to RearwheelNick with someone else on 1st refusal ;D
Last Edit: Jan 5, 2006 19:41:01 GMT by CR500Dom
Nick
hmm.. i don't have any heaters hehe;)
looking forward to getting my mitts on there
