Jan 23, 2005 11:50:18 GMT
Okay I've been looking at lowering springs for the Golf,.. It seems like its here to stay,.. so... might as well have it how I want it. I want it lower! ,.. however I don't want to chop the springs and compromise the ride as its used everyday (usually by my other half) ,.. So I've been looking at lowering kits and more specifically lowering springs because frankly I don't want to pay out on a whole bunch of new shocks etc. Awesome GTi has these options : www.awesome-gti.co.uk/vw%20golfmk3/suspension.htmlThere is a 45-50 drop for later models, but sadly mine isn't a late model,.. so the only spring based option I've got from them is 30mm ,.. which (having measured it this morning) is frankly rubbish. So anyone know of any other people that would do a lower kit? Or any other way to drop is safely without cutting springs and maintaining ride quality!
Jan 23, 2005 11:58:44 GMT
C&R
demon tweeks
failing that try the back of **cough** Max Flower
Dub Sport
2001 HONDA CT110 (NOT RCV)
Jan 23, 2005 12:01:16 GMT
Jan 23, 2005 12:05:02 GMT
Jan 23, 2005 12:05:13 GMT
Oooh Demon Tweeks have come up trumps with a set of Spax springs that'll do 60mm
Jan 23, 2005 12:17:57 GMT
David: Can you get the part number for those spax bits? (The spax one not the Deemon Tweeks one obviously!) I'll see if I can get them cheaper! My dad sells the odd suspension kit in his shop - I'll do some arm tristing to get them at cost. Figure I owe ya a favour...
Last Edit: Jan 23, 2005 12:19:28 GMT by nickb
Jan 23, 2005 13:56:40 GMT
must be nice to be able to get stuff like that off the shelf.I'm having to get some made.so ive just ordered a set off 80mm lowered springs for the front of my merc.the guy said i should have them within 20 days of the cheque clearing. il be putting them straight on come rain,hail or shine.il post pics when its done. ;D
Jan 23, 2005 13:59:50 GMT
David: Can you get the part number for those spax bits? (The spax one not the Deemon Tweeks one obviously!) I'll see if I can get them cheaper! My dad sells the odd suspension kit in his shop - I'll do some arm tristing to get them at cost. Figure I owe ya a favour... Oooh bonus ,.. I'll have a check and see if I can get the info ,..
30mm?? Thats rubbish!!DarrenW
@darrenw
Club Retro Rides Member 74
Jan 23, 2005 14:06:24 GMT
My Mk1 is dropped 30mm, which isn't nearly enough... Must sort that out sometime! Slight tangent, but rather than rattle-can paint, how about some lovely fablon:
Jan 23, 2005 14:16:52 GMT
Slight tangent, but rather than rattle-can paint, how about some lovely fablon You need to see someone about your Fablon obsession
Jan 23, 2005 14:49:11 GMT
euro car parts mate u could do worse
"quote hairnet"
I'm not paying nine pound for a pi$$!
[/quote]
Ed
Jan 23, 2005 14:56:47 GMT
lower a car more than 40mm and you are normally recommended to have shortened shocks. you can probably get away with 45mm id have thought. ive just cut the springs on the passat....drives sweet as a nut...only did 1.5 coils...gonna take the extra.5 off to really slam it
30mm?? Thats rubbish!!BenzBoy
@benzboy
Jan 23, 2005 15:28:51 GMT
They recommend shorter shocks because the originals are designed to operate within a certain space within the damper. If you lower the car, the damper piston operates higher up the shock, and if it goes too high it'll collide with the top of the damper body and knacker the piston/valve assembly. Also, the uprated shocks will be designed for the higher performance spring, so you'll get a better overall ride.
