Hi all. My name is Adam and this is my first post but I have been lurking around here for a while now and have just bought me another ae86 Levin so space is and issue and this has to go, otherwise I would keep it!
1981 KP61 RWD Starlet for sale
This car is just a a shell and is a non sunroof, 3 door model showing 60k.
It has some small rust areas and is in great condition for its agae.
It was an auto, but this is a good thing as the transmission tunnel is larger to allow diffrent gearboxes from other cars to be used if you do an engine swap!
Also have a 4k (1.3) engine that has
•lightened flywheel
•new clutch
•uprated cam
•uprated valve springs
•baffelled sump
•high compression
•ported carb
This engine should see about 100bhp and is a great motor that has been buil arond 1000 miles ago. it like new and is in great condition
also has a k40 4 speed gearbox
Also included are a set of front adj coilover with camber adj top hats and a set of Spax adj rear coilovers
Also included are a set of 4 fiberglass whell arch flares still to be added as thes allow wder whells to be used (these are just small flares, similar to te27 flares but from a Datsun mold- unsure which)
As I said, the car is fully stripped as I was planning to seam weld the car and completely respray the shell.
It has all the standard parts and everything
Also included extra in a complete 1979 kp60 5 door Starley (RWD) as a spares car. It still has MOT but no tax and is missin all the fron t pannels and has damage to the rear quarter so cannot be put back on road.
This is to be used for my project as spares to help me if anything breaks and has only done 42k!!
Only thing needed ar better fron and rear bumpers as these have seen better days!
So what am I looking for the whole car....
£1150 ono
the engine is worth £400 on its own and as I said there are alot of spare which are so hard to get now for these
Well if you are prepared to put the effort in I thnk you could have such a cool car !
anyway my number is 07841045022
Thanks
Adam
•lightened flywheel
•new clutch
•uprated cam
•baffelled sump
•high compression
•ported carb
£1150 ono
Thanks
Adam
