T-piece... where from?BenzBoy
@benzboy
Club Retro Rides Member 7
Mar 28, 2008 22:20:42 GMT
I need a t-piece. M10x1.5 female one end, M10x1.5 male on the other end, and either a 1/8 NPT or preferably a -3AN fitting in the middle, for the turbo oil feed. The third fitting depends on what sort of oil supply line I'll be using really. I'm thinking a -3AN braided teflon hose with a banjo bolt fitting the other end, as the turbo has a Banjo on the steel feed pipe (M16 or something) Anyone know a good source? All the ones I can find are 1/8 NPT or BSPT or somesuch Sorry, bit of a dull techy thread but any ponters / advice / help is welcome!
Mar 28, 2008 22:32:06 GMT
Any of your local industrial hydraulic factors should carry stuff like this, I use mine for all manner of adaptors, might need to mix and match a couple of things to get all the sizes but that where I'd head first. Pirtek and similar or there should be a local independent somewhere nearby I'd guess
2014 - Audi A6 Avant 3.0Tdi Quattro 1958 - Chevrolet Apache Panel Truck 1959 - Plymouth Custom Suburban 1952 - Chevrolet 2dr Hardtop 1985 - Ford Econoline E350 Quadravan 2009 - Ovlov V70 2.5T 1970 - Cortina Mk2 Estate 2007 - Fiat Ducato LWB 120Multijet 2014 - Honda Civic 2.2 CTDi ES
Mar 28, 2008 23:38:34 GMT
www.nuneatonhose.co.uk/this is the place i have been using recently, there should be a place nearer you but its not a million miles away. Places like this i've found particularly like to be paid cash - eg "that would be £27+vat or £20 cash sir..." although saying that one M10x1.5 fitting i needed they didnt do as its primarily a automotive fitting, vehiclewiringproducts.co.uk do all sorts of these for brake fittings. As said you may end up mixing and matching, might even be better getting a machine shop to make something Mike
@benzboy
Thanks guys I'll check those links out. There's a hydraulics place down the road from me so I'll try there - I could even take the turbo down there to make sure I get the right size banjo bolt.
Mar 30, 2008 10:31:15 GMT
1952 Ford Pop----------- 460ci 1975 Ford MustangII--- 302ci 1980 VW Polo--- -------- 54ci
rtlkyuubi
Low and Slow
Mar 30, 2008 10:43:53 GMT
bit o/t like but how do you measure what size adaptor you need? I need to buy an adaptor so i can run an oil pressure gauge and I don't know what size it needs to be.
@benzboy
Mar 30, 2008 11:06:02 GMT
bit o/t like but how do you measure what size adaptor you need? I need to buy an adaptor so I can run an oil pressure gauge and I don't know what size it needs to be. I took the oil pressure sender pipe from the block and just tried different taps in my tap and die set til one fit it!;D Do you have a place in the block or head like a blanking plug? If you take that out you should be able to find the size you need to go into the block. As for the oil pressure gauge, whichever one you buy should have the fitment written on the packaging or something.
rtlkyuubi
Low and Slow
bit o/t like but how do you measure what size adaptor you need? I need to buy an adaptor so I can run an oil pressure gauge and I don't know what size it needs to be. I took the oil pressure sender pipe from the block and just tried different taps in my tap and die set til one fit it!;D Do you have a place in the block or head like a blanking plug? If you take that out you should be able to find the size you need to go into the block. As for the oil pressure gauge, whichever one you buy should have the fitment written on the packaging or something. I'm gonna buy 1 of them split off adaptor things where it uses the oil pressure switch hole. I also got the guage for free so i didnt get an adaptor or anything with it
Try Think Auto (http://www.thinkauto.com/)...
