Mar 26, 2008 15:46:12 GMT
My mum's moggy minor 1000 is having fuel pump problems
Ignition turned on there is not the usual tic-tic-tic, which I know tends to signify burned/dirty/pitted points but I've cleaned the points and they seem free
I've had the rest apart, cleaned all terminals, checked grounds etc and can't find anything amiss. The weird thing is however, with the ignition on, and loosening the terminal screw off, then giving the cable a wiggle starts the contacts ticing but only if the wire is moved around.
My main domain is yank stuff and mechanical pumps so I'm a bit stuck for ideas, any help is appreciated
cheers!
not all that is retro is cool....
SU Fuel Pump?BenzBoy
@benzboy
Club Retro Rides Member 7
Mar 26, 2008 16:18:06 GMT
I'm confused! Are you talking about the ticking of an electric pump, or the the points in the dizzy?
Mar 26, 2008 16:27:12 GMT
My mum's moggy minor 1000 is having fuel pump problems Ignition turned on there is not the usual tic-tic-tic SU pumps only "tic-tic" when they are pushing fuel through anyway - sat at rest with the ignition on it shouldn't really do much, with the engine running it should tic slowly, if you pull the fuel line off the carb and put it in a can, it will tick like a torettes sufferer on red bull! I use SU pumps for racing and they often seize on me when they've been sat - what I do is take the 10mm nut off the positive lug and remove the points cover, clean the points up, maually pump the little oscilating arm thingy a few times, put a new earth wire to the pump body and a decent wire to the positive lug and then run straight off a battery for about 10 seconds, then try it pumping a bit of fuel between 2 cans for a test before refitting - usually gets them going again OK for me
Seth
Mar 26, 2008 16:29:29 GMT
Hmm, is it a recent pump or the original/old one. I have had a pump that has given up the ghost even with new dual contact points fitted. Only thought I could come up with was that through age the magnets in the solenoid might have weakend so the plunger bit of the pump wouldn't work consistently. Might be that you wiggling the lead is giving voltage spokes to jump start it but it can't keep itself going. Benzboy, the ticking of an SU pump is controlled by a set of points
@benzboy
Mar 26, 2008 16:31:41 GMT
Benzboy, the ticking of an SU pump is controlled by a set of points Ah I see! Thanks for educating
Mar 26, 2008 17:47:49 GMT
It used to tic for a bit as soon as you turned the ignition on, the magnet thing had crossed my mind - I don't think its an original pump but it isn't particularly recent, a good few years ago (10+ probably) my neighbour either replaced the pump or gave it a rebuild.
harris66
drive it, break it, fix it and make it quicker!
Mar 26, 2008 17:50:26 GMT
in my past expereince of old su pumps id bin it and fit a new 1, they can be a pain in the wotsits,
1.2 corsa daily, 1.8t a4 avante, 6.3ltr austin a40....
Mar 26, 2008 18:21:36 GMT
Coincidently my mum also has a moggy minor (but she has a van), her fuel pump caused her to break down last week, I cave the pump some physical abuse at the roadside and it hasn't been a problem since.
Cant help you though sorry.
Mar 26, 2008 18:29:00 GMT
Mine is working fine, never touched it.. But it thuds like mad. Is it on its way out or not?
Mar 26, 2008 21:30:10 GMT
pull the little filter on the underside of the pump out, if its jammed with crud the pump *may* stall. under the 3/4 IIRC nut at the very bottom of the pump head
Mar 26, 2008 23:11:13 GMT
ditch the su pump, they work well when they work but leave them sitting for more than a few months and the stick. Fit a Facet and a regulator and you wont go worng.
BTW did u check to make sure the diaphram hasnt persihed on your pump?
Mar 27, 2008 14:52:10 GMT
Don't think its the filter, had that all apart and the fuel inlet/outlet flow fine, no blockages and the ball valves are working
Diaphragm looks fine too
Mar 27, 2008 23:41:49 GMT
Theres 2 options fit a mechanical pump if yours has the removable plate on the back of the engine or fit the uprated electronic one from Burlen fuel systems,it looks identical to the SU pump but has electronics instead of points in it.
