Guys and gals,
I've got a fair bit of personal experience with cancer. My friend John died from leukemia, my uncle had cancer, and agressive cancer made my partner take his life.
I also know, as I imagine many people here do, many people either with direct experience or have had friends/relatives who suffer/have suffered.
Many of you probably run SETI and this program works along the same lines apparently.
Essentially, it downloads a chunk of data and runs processes while your PC is idle to match drug molecules to cancer cells, with the intention of making more effective drugs with fewer side effects (or so I understand - I'm very tired at the moment so can't quite take all of the information in).
Like SETI, its anonymous and safe.
If you would consider running this, then I would be most grateful. It is of more benefit to humanity than the SETI project. And, if you approve of it, I would be grateful if you could post the following link up on any other boards that you may use around the internet, basically just publicise its existance.
This is the link for the main site:
www.grid.org/projects/cancer/
I have created a team for this (rather like the SETI team)
ANd I've called it simply "Doing it for Love"
If you want to join up with this, then come and join in whic this team. There are 83 members and in about 13 months we have clocked up over 27 years of processor time!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
Go to this webpage to sign up
www.grid.org/services/teams/...D6-706987605C09
IMPORTANT NOTICE
DO NOT INSTALL THIS ON A WORK PC WITHOUT CHECKING WITH YOUR IT TEAM, IN SOME CASES IT IS CONSIDERED THEFT OF COMPUTING RESOURCES AND IS A DISMISSABLE OFFENCE
Also, the program units a small pox vaccine routine as standard. I, and many others, have this turned off so that we ONLY crunch the cancer stuff.
To turn it off, log into the United Devices page with your user name
Click on "My Device Manager"
Click on "Profiles"
Click on whichever profile you want to edit (all my devices are set to "Default")
Down the bottom of the screen there are 2 tick boxes - one for UD Cancer Research Project and one for "PatriotGrid running the Smallpox Research Grid Project".
If you wish NOT to run the smallpox project, ensure that the box is NOT ticked, then click save.
IMPORTANT NOTICE
Click on "Profiles"
