Well I've almost finished rebulding the front suspension but I have hit a snag.
I can't get the top trunnion bushes into the damper slot. I've tried compressing them with a G-clamp to no avail. but they just won't go in . The distance from bush to bush is about 5.5cm. The damper only allows for under 5cm to go in! I've tried the hammer etc. and I'm running out of ideas.
What do you recommend and how have some of you gone about doing this in the past?
Here are some pics hopefully to show the problem:
