spiny
Wiki Admin
I am abivalent towards car electrics ...
Club RR Member Number: 167
tech: Peugeot 205 1.1 no startspiny
@spiny
Club Retro Rides Member 167
Dec 27, 2004 15:08:16 GMT
Anybody got any hints on what to look for on my 205 - it was working fine yesterday, today, no start, just turns over and over.
I've replaced the cap and arm, cleaned the leads but it seems that there is no spark. I've tried a known good coil, no go.
I'm curse word livid at the moment, so i'm going for a walk.
at least i'm on holiday ...
curse word fuckity curse word.
Dec 27, 2004 15:30:19 GMT
try changing the ignition amplifier, depending on the year it'll either be mounted on the dizzy or on an alloy plate next to the coil. I used to work at a peugeot garage and these were known for going tits up.
spiny
Wiki Admin
@spiny
Dec 27, 2004 15:34:35 GMT
yeah, it's on the ally plate ...
i've checked pretty much everything else, so it would be the one bit i can't get today - the scrappys are closed and i'm not buying a new one, it's probably more than the cars worth.
just checked gsf - 20 quid, hmmmm
Dec 27, 2004 15:38:02 GMT
if its got leccy ign if theres a sensor in the dizzy - might be that fail without warning..
known for it on vws so might be your prob - symptoms sounds same as what happened to my polo
2001 HONDA CT110 (NOT RCV)
Dec 27, 2004 15:42:46 GMT
20 quid sounds like a bargain to me, i rekon you'd be lucky to get a second hand one for less than a tenner and that could be on the way out too. I think this is your problem, like you say you've checked everything else, although i remember replacing coil, dizzy and ignition pack on my old transit once just to find that it was the coil lead breaking down under load, DOH!
spiny
Wiki Admin
@spiny
Dec 27, 2004 16:42:39 GMT
is there any way to test the coil pack, with a meter etc ?
doesn't look like i'm going anywhere tomorrow ...
Dec 27, 2004 21:11:33 GMT
It can be done but i cant remember for the life of me how to do it. You need to measure the resistance between the pins but i cant remember what pins and what the resistances are If you can get hold of the old style haynes manual (the ones before they made them for idiots) it tells you in there how to do it.
spiny
Wiki Admin
@spiny
Dec 28, 2004 13:07:24 GMT
curse word, i have the 'see your peugeot dealer' one.
how easy is it to remove the dizzy? it looks -really- fiddly?
Dec 28, 2004 16:37:01 GMT
If its the ohc engine then its just 2 11mm bolts and unplug the loom. If its the old rattlebox engine then i think its a 13mm holding the clamp on but its a bit awkward cos the dizzy gets in the way. The ohc dizzy only goes in one way but the ohv one dosent, so make sure you mark it before you take it out.
