Last Edit: Jan 4, 2008 20:46:53 GMT by akku
red ? cos it'll put you in it asap
kevfromwales
the conrod's REALLY out the block now!
get them slot mags on it, that'll be less weight to carry round! I was talking to the mate that I got your wheels off ak, and they did actually come off a tina (a mk4 though) - which he got in, took the wheels off - and baled!! - kev ps - 19.1 mpg? - think the hunter does around that, or at least it feels like it does (wallet empty)
Almost on the road: b11 sunny breadvan, e36 tds, 325i skidcar,
nearly there: ford f250 tathauler, suzuki alto, u11 bluey
not for a while: ford pop, 32 rails,
not in this lifetime: ruby, '29 hillman
''unfortanatly I'm quite old and scruffy and in need of some loving. my drive shaft needs a new boot....''
I always wash my cars before I ebay them, usually cos they are filthy!
bit chilly without a rear window
having a car wet in the photo "covers up" that the paint is matt and the body is dinged. So a wet car I assume to be bad of body.
rear screen is an issue. probably will result in a no-sale because of it. glass for those tanks can be hard (or at least expensive) to get hold of
Oh, I do like that olds.
don't touch the paint, Leave the back window missing and get your mates to shoot at the police out of the hole. ;D
and 19mpg?? damn, man, what axle ratio are you running? (is just a 2.0 pinto innit? you havn't been swapping in a RR merlin on the sly?)
v8lee
FoMoCoMoFo
People always wet tyres when they put them on ebay. What's that all about? Suppose it makes them look newer.
Older cars are green. Recycling them uses up loads of energy as does manufacturing a new replacement. Retro driver = Eco warrior / tree hugger.
No more old cars
having a car wet in the photo "covers up" that the paint is matt and the body is dinged. So a wet car I assume to be bad of body. rear screen is an issue. probably will result in a no-sale because of it. glass for those tanks can be hard (or at least expensive) to get hold of It`s recent rain that is the friend of the not-nice car. All those little globules of water take the eye off everything. Washing a car and leaving it to dry can actually accentuate grisly bits of paint, I find.
I can get 19 out of the Grey whale if I go more town than motorway. And that is a 4.0. WTF are you doing?
Hirst
This avatar is inaccurate, I've never shaved that closely
People always wet tyres when they put them on ebay. What's that all about? Suppose it makes them look newer. Most of the time it is wet-look tyre shine. Sounds like a minor thing, but blacked up (wet-look or not, up to you) tyres can make a massive difference to the overall look of a car. It's a nifty little trick!
fuel consumption has been dropping off for a couple of weeks. Tine to do a bit of a tune up I suspect. But its mostly city driving, cold weather, fair amount of idling to warm it up, that sort of thing.
Its got the 1600 xflow rear axle / diff.
gloss blacked tyres (pretty much) always look awful. ALways makes me thing "tarted up knacker"
the old fairy liquid trick is good for tyre appearance, but i think last clean, a mix of bike cleaner 'Sh1t Shifter' with brush on the wheels and tripplewax shampoo everywhere, cleaned tyres up a treat with min effort. scary fuel consumption a service could save a few ££'s over the coming weeks by sound of it.
at least you have power for your mpg. i got 19mpg over 2 months in a 1.2L.
on motorways.
Power? its a 2.0 Pinto!
pinto v. 1174cc skoda engine? you're still gonna win that drag all day long Al
Soopra
Grey? Black? Brown? The Cortina has excellend itsenf and returned 19.1 MPG this week. 200 miles on just over £50 worth. Blimey. thats what mine was doing with a knackered 2.3 engine... not sure what my new 2.8 will be like you should get nearer 30mpg on a run
For mine is the Supra, the power and the glory...
bryn
That's really not very good is it? I thought the Range Rover I've just bought was bad at 13mpg, but that's on LPG and it'll pull 3.5tonnes... You need to be doing something about that really.
Tim
i thoight it was a x-flow? :-)
its a 2.0 pinto in a 1.6 crossflow car. 'box and axle are both x/f spec. I usually get 23-24 MPG out of it which is what I got out of my 1600 crossflow one before it. (although its been going downhill a bit since before xmas) And its not far off what Ford claim is the MPG for the car. The 2.0 is far better on fuel than the 1.6 x/f mostly due to the torque improvement allowing far taller gearing as well as you being able to drive on the torque curve not on the power curve and getting more for your gallon that way. I've had 30 MPG out of my old 4 speed manual 2.0 Cortinas, if driven really gently or on long steady runs. I'd expect upper 20s from a stock 2.0 driven "normally". I'd expect mid 20s from a 2.0 with 1600 x/f gearing. The car is used very much for "mixed" driving. Commute to work, a few longer runs but with todays traffic you never get the long clear runs we used to.
Last Edit: Jan 7, 2008 12:31:15 GMT by akku
