slater
Club RR Member Number: 78
Place bets now!slater
@slater
Club Retro Rides Member 78
Will someone die! Or is that someone will die!
CUT BIN CUT again HEAT (a bit) PLACE WIN For the exicting conclusion to this episode tune in when i can be arsed to finish it!
Shrunk fit?? Is there anything you don't modify? I bet you're toasters dangerously quick ;D
Faster. Faster. Until the thrill of speed overcomes the fear of death.
SKILLZ!! you welding 'em or your old chap?
markbognor
Club RR Member Number: 56
Place bets now!markbognor
@markbognor
Club Retro Rides Member 56
Just about to ask the same, Re welding, presumably the interference fit is added security, ease of centering the location of the rim.
My bet is that the osf boys will make you rich this summer.
slater
@slater
Yeh, il have a go at welding it sometime. Better than going to the scrap man eh?
rysz
Slater, your workmanship is superb! Just about everything that you touch, is sublimely executed!
Also, what markbognor said!
BiAS
Insert witty comment here
Club RR Member Number: 147
Place bets now!BiAS
@cheeqi
Club Retro Rides Member 147
That is teh secks! You got the mad skillzors ;D
(car+wheels)-rideheight=WIN
topi
It's a race car officer, I swear!
So you've turned 2 normal RS 4spokes into 1 wide one? Ha cool.
Place bets now!stealthstylz
@stealthstylz
Club Retro Rides Member 174
If that welds OK it'll look brilliant. What size are they now about 13x9?
Matt
If you pull that off successfully I think I'll be buying up some more Lotus rims! I'm guessing that a conversion to split rim outers could be done the same way.
slater
@slater
Oh yeh the Split rim coversion is relly easy. You just need a rim the right size and a wheel with some meat in the right place!
I want to do cloverleafs but the lathe aint big enough!!
oh and 13x8 i think
Got me grinning wildly again Slater. ;D ;D ;D
BiAS
Place bets now!BiAS
@cheeqi
I want to do cloverleafs but the lathe aint big enough!! I think you may have made me realise why i don't like cloverleafs Not enough damned dish! Yes indeedy, 14x8 cloverleafs FTW
@stealthstylz
Could you use a large + offset wheel as the new dish part to make a super dished version? I'm thinking silly dished saab inca would be the winner of ever. Matt
slater
@slater
aghh its starting again!! 3 PMs in the last 5mins 'can you please make me some'
Now i don't blame you for asking, but, ive only made half of one wheel so far, i have no idea if it will work and it wont work for all wheels, It only just about worked for these.
If i do maybe make some for someone then it will probably be a minimum of £100 a wheel its not simple and quick! and at present i cant do anything bigger than 13"s. Might be able the stretch to some 14"s if i made special soft jaws but i don't have any to hand atm!.... and.. like i said, without some indepth measuring i cant tell you if its possible with any specific wheels.
That said if i finish this pair they might be for sale!
Davenger
It's only metal
Club RR Member Number: 140
Place bets now!Davenger
@dminifreak
Club Retro Rides Member 140
Dude, is there anything you can't do? I reckon you should finish a set and put them on that MK1 Escort you keep threatening to finish.
slater
@slater
If there are any tyre fitters are in the house can you offer an oppinion on how hard it might make your job?
