Dec 30, 2007 20:42:12 GMT
I have to say muchos gracias to Benzboy and Pillock who dropped by yesterday to particpate in the chaos which is a mechanical project here... Plan was to refit the trans into the Oldsmobile. Much deep thought required before hand The Benz. And another R-R car sits on my drive.... Kevfromwales' Hillman was there not a week before. Many cool cars. The trans itself. Initial enthusiasm.... and not a small amount of split trans fluid. How much ATF can you get in a torque converter? bit more standing around. considering. planning. shift yet more slot mags out the way so we can get up the side of the car And have a cup of coffee Big block Olds. Now where do all these little bits go? As we have no npbbet prop on the car I use a bit of re-enforcing rod to prop it open. Ever the safety man Pillock suggested adding a couple of cable ties. Safe as houses. Those Jacks look really weedy under that car.... Even thought hey were only used to jack the trans not the car itself.... Ever had a trolley jack fail on you? I have. Funkin scary. Benzboy in some form of purplehaze or something, and back in reality "to me, to you" Pillock gives his seal of safety approval to the use of wooden stuff wedged under the car soaked in ATF. but finally, after Benzboy appeared with a length or railway sleeper (seriously) out of the boot of his car we were able to use three trolley jacks, two bottle jacks, a scissor jack and sundry bits of wood to pursuade the trans back into position. These funkers weigh in at 175 lbs without the torque converter. Heavy metal indeed. And yeah, after we had to push that sodding Buick up the drive to move it the first time it started and ran fine when it was time to put everything away.... Meh. Just got to put the last of the bellhousing bolts in, nip everything up, rebilt the torque converter to the flex plate, connect up exhausts and coolers and all that and then we can see if it actually drives now.... anyone taking bets?
Dec 30, 2007 20:44:28 GMT
I bet you a beverage of choice it goes and goes WELL! Great stuff Bet it's a relief and a half just to have the damn thing back in the car and not on a bench ;D
Last Edit: Dec 30, 2007 20:44:42 GMT by Lewis
v8lee
FoMoCoMoFo
Dec 30, 2007 20:53:21 GMT
I recognise at least one pair of those slot mags. The answer to the question "How much ATF can you get in a torque converter?" is - loads. And if you think ATF stinks try friction modifier, which is what my garage and entire house currently smell of. Are you firing it up tomorrow? I might pop round to lend some moral support (and have a cup of tea).
Last Edit: Dec 30, 2007 20:54:47 GMT by v8lee
No more old cars
Dec 30, 2007 20:55:06 GMT
Bench? floor...
I thougth that it was gonig to be a work of hercules to get that back in withlimited clearance workign from underneath like that but after a certain amount of sizing it up it all seemed to go pretty much to plan.
We did have some ace innovations like trying the torque converter on with gardening twine (I'm sure that the GM facroty tool is exactly the same, right?)
Until its moving about under its own propulsion I don't plan on cracking any beverages in celebration. Those TC seals are notroiously easy to damage/push out and I do recall when we took it out we dropped the converter itself...
We shall see.
Jst got to find the time to finish it off now.
Seth
Dec 30, 2007 20:56:42 GMT
Looks like a good use of Team R-R once again Hope it all works AK!
Dec 30, 2007 20:56:43 GMT
Lee, not firing it up tomorrow. Need to refill and let it sit 24 hours I guess as its been a few weeks since the seals were soaked and fitted so they'll want to see some more fluid and soak again a bit. You're welcome for a cuppa. Not sure if we are going shopping part of the day but I'll see if I can get out of that as I've had man flu all day today. Give me a call or text.
And yeah, thay could well be those slots. Appliance?
Last Edit: Dec 30, 2007 20:58:06 GMT by akku
Dec 30, 2007 21:13:00 GMT
It went pretty seamlessly didn't it? It was a good lark, I like doing stuff like this (particularly if a garage is involved!) I'll pick up my overalls at some point... they're ripped to b*ggery but they match my car ;D ;D
Dec 30, 2007 21:44:28 GMT
3 pics with hands in overalls pockets and they get sewn up, Pillock, you have been warned
Dec 30, 2007 22:04:54 GMT
I have to say the pics are not representative, Pillock was gettin ghis freak on that box like Russel Grant on a freshly greased quior boy.
stinkwheel
Doctor Of Gonzo Journalism - One of gods own proptypes, never even considered for mass production.
Dec 30, 2007 22:34:35 GMT
thats image is wrong in so many ways, good work on getting it all together though. What size motor is the BB in the olds AK, is it a 403?
1973 Citroen Dyane 6 1980 Citroen Acadiane 1992 Citroen AX 1990 Citroen BX 1997 Citroen XM 1993 Citroen BX 1997 Citroen Xantia 1977 Citroen Ami 8 1996 Ford Escort 1989 Citroen BX 1997 Suzuki RF900 1988 Yamaha TDR250 1979 Honda CB400. 'I need less vehicles'
MartinC
Don't like stretched tyres, very low profile tyres & I think a car CAN be too low. Perhaps I'm odd.
I love the pic showing the axle stands under the front bumper. Only on a yank...
1937 Standard Flying Twelve
1943 Bedford OYD
1947 Cadillac Fleetwood Sixty-Special
1954 Hillman Minx MkVIII
1956 Austin A30
1957 Vauxhall Victor Super
2001 Chrysler 300M
2002 Rover 75 Connoisseur SE Tourer
I have to say the pics are not representative, Pillock was getting his freak on that box like Russel Grant on a freshly greased quior boy. Erm.......! All went a bit well though I think, that's a bloody heavy trans! Fingers crossed it's all groovy..... been a learning experience
Dec 31, 2007 11:54:07 GMT
Yeah, part of me things it went a little too well... I hope it's all good! Nice to meet you Pillockio!
Dec 31, 2007 12:13:29 GMT
It's all about stance and you have it spot-on BB. Mug in hand, having a sip. *n
Dec 31, 2007 13:02:14 GMT
What size motor is the BB in the olds AK, is it a 403? 425 "Super Rocket" 7 litre 375 BHP and 485 lbs torque. The bumpers are where you are supposed to jack & support them. Says so in the manual. The frame horns on those are HEAVY DUTY steel section!
Dec 31, 2007 16:24:37 GMT
Benzboy in some form of purplehaze or something, he always looks like this to me, cant imagine why ;D well done fella,s!
"quote hairnet"
I'm not paying nine pound for a pi$$!
[/quote]
Dec 31, 2007 16:34:38 GMT
Yeah, part of me things it went a little too well... I hope it's all good! Nice to meet you Pillockio! Hey you shoulda seen it come out..... Alistair had the car supported on his back and I leaned in and took the trans out under my arm. Simple. 3 hours supping tea and 25 seconds to do the job. Honest Hehe great to meet you - and the Benz! Still think there's some heavy-duty David Blaine going on with that arch clearance though
Dec 31, 2007 16:48:53 GMT
arch and rubber seem to intersect. Its like one of those drawings of a physical impossibility....
Last Edit: Dec 31, 2007 16:49:06 GMT by akku
Dec 31, 2007 17:06:56 GMT
Not by your book, maybe! I thought I followed it pretty well....
