Dec 29, 2007 14:04:04 GMT
Well, it seems there is not a lot about with them.... Transit, Transit, Transit. I want to see what was made over the years in either steel, or alloys for them. Please show me, and if someone has a decent set to offload, let me know as well please. Here are pics of my new rides Wheels, fitted, so look, and then show or let me know. REAR. FRONT.
mrj
Dec 29, 2007 14:07:19 GMT
wow, Metzeler tyres, they stopped producing car tyres at least 20 years ago this will be hard, i think some pcd-adaptors will be the solution....
- 1971 VW 1600 TL Fastback - 1978 Passat GLS Variant - 1980 Audi 100 5E - 1981 VW aircooled panel van (sold) - 1983 VW Jetta Mk.I - 1984 VW Polo Coupé - 1984 VW Passat hatchback - 1987 VW Passat Variant - 1987 VW Passat hatchback - 1988 VW T25
Dec 29, 2007 14:10:26 GMT
wow, Metzeler tyres, they stopped producing car tyres at least 20 years ago this will be hard, I think some pcd-adaptors will be the solution.... Hallo Jeurgen, with only 7616 km done, I suspect these are the original tyres ;D ;D ;D Perfect for motorway speeds then
Dec 29, 2007 14:17:58 GMT
Dec 29, 2007 14:22:45 GMT
Can you drill the hubs to wide 5 beetle?
Matt
Dec 29, 2007 14:37:14 GMT
Now is this OOOFFFF-worthy on a van ?? 5x160, but will they fit my van ?? And these are a correct fit too (apparantly ) I can imagine spending a day cleaning them and detailing them..... they should fit the period look of the van.
Dec 29, 2007 14:39:20 GMT
Thanks Mate, they are 14's and I want 15's as the drop etc combined will need 15's to pull it off.
Dec 29, 2007 14:40:11 GMT
Anglia68
Powered By Boredom.
Dec 29, 2007 14:45:02 GMT
There must be Slot Mags out there and maybe even TurboVecs,loads of custom transits had them fitted back in the day. According to that site SlotMags are too rare and you've already posted a pic of TurboVecs so I'm being of no help wotsoevar.
Last Edit: Dec 29, 2007 14:49:12 GMT by Anglia68
Dec 29, 2007 14:45:50 GMT
land rover 5x165 would that be close enuff to fit?
2001 HONDA CT110 (NOT RCV)
Dec 29, 2007 14:51:31 GMT
There must be Slot Mags out there and maybe even TurboVecs,loads of custom transits had them fitted back in the day. Yep, I think they could work if detailed and painted correctly. Slots are apparantly not common. However I know of a certain member here who knows them intimately.... If in a 15 inch size slots could come into play. I like some moderns, but then there is a lot to be said for keeping traditional wiht the look I am creating. By the way, other than JamesP who may not be able to handle 5 stud through his guy, are there any recomended banders out there ? Who do not rip the arssse out of it price wise, and deliver a decent job banding wheels?
Dec 29, 2007 14:52:16 GMT
land rover 5x165 would that be close enuff to fit? Good call, but Transit guys do not recommend it.
Anglia68
Powered By Boredom.
Dec 29, 2007 14:55:14 GMT
I seem to remember that P100's use the same stud pattern so that might be of some use and they end up with all manner of wheels on them so there must be an easy solution out there.
Dec 29, 2007 15:00:36 GMT
Most convert p100s to sierra hubs for 4x108.
Matt
Anglia68
Powered By Boredom.
Dec 29, 2007 15:26:55 GMT
Aaahhh!!! you learn something new everyday a round here.
Dec 29, 2007 15:47:44 GMT
If Sierra hubs fit a P100 which normally uses Transit-style 5x160, will Sierra hubs not fit a Transit?
Dec 29, 2007 16:58:54 GMT
P100s are 5x127mm (5"), not 5x160.
I've just dug out the old SM that dealt with Transit wheels swaps where it suggests using an adapter from the front backwards - taking it from 5x160 to 5x108 (Volvo, Ferrari and various modern things!). The adapter in question is fitted to Mk3 Transits (the last RWD ones).
Dec 29, 2007 18:24:41 GMT
could u not fit different hubs so lotus cortina wheels fit??
Dec 29, 2007 19:17:08 GMT
could u not fit different hubs so lotus cortina wheels fit?? Lotus 'Tina rims are 13" and not exactly cheap! ;D
Dec 29, 2007 21:11:00 GMT
I reckon you might be onto something there rmad.
Matt
