For those who haven't used a Haynes Manual, these are the books aimed
at those who want to fix their own vehicles and which keep qualified
mechanics in paid employment putting things right afterwards. They are
chock full of photos, diagrams and step-by-step instructions which are
obvious if you are a fully qualified motor mechanic, but which are
frighteningly sparse on detail for the average Joe in the street who
wants to change a set of spark plugs on a 1981 VW Polo ....
Hers are some of the more common phrases found throughout the manuals
and their translations into real world english.
Haynes: Rotate anticlockwise.
Translation: Clamp with molegrips then beat repeatedly with hammer
anticlockwise. You do know which way is anticlockwise, don't you?
Haynes: Should remove easily.
Translation: Will be corroded into place ... clamp with molegrips then
beat repeatedly with a hammer.
Haynes: Remove small retaining clip.
Translation: Take off 15 years of stubborn crud, it's there somewhere.
Haynes: This is a snug fit.
Translation: You will skin your knuckles! ... Clamp with molegrips
then beat repeatedly with hammer.
Haynes: This is a tight fit.
Translation: Not a hope in hell matey! ... Clamp with molegrips then
Haynes: As described in Chapter 7...
Translation: That'll teach you not to read through before you start,
now you are looking at scarey photos of the inside of a gearbox.
Haynes: Locate ...
Translation: This photo of a hex nut is the only clue we're giving you.
Haynes: Pry...
Translation: Hammer a screwdriver into...
Haynes: Undo...
Translation: Go buy a tin of WD40 (catering size).
Haynes: Ease ...
Translation: Apply superhuman strength to ...
Haynes: Retain tiny spring and/or ball bearing
Translation: "Jeez what was that, it nearly had my eye out"!
Haynes: Press and rotate to remove bulb...
Translation: OK - that's the glass bit off, now fetch some good pliers
to dig out the bayonet part and remaining glass shards.
Haynes: Lightly...
Translation: Start off lightly and build up till the veins on your
forehead are throbbing then re-check the manual because what you are
doing now cannot be considered "lightly".
Haynes: Weekly checks...
Translation: If it isn't broken don't fix it!
Haynes: Routine maintenance...
Translation: If it isn't broken... it's about to be!
Haynes: One spanner rating (simple).
Translation: Your Mum could do this... so how did you manage to botch it up?
Haynes: Two spanner rating.
Translation: Now you may think that you can do this because two is a
low, tiny, ikkle number... but you also thought that the wiring
diagram was a map of the Tokyo underground (in fact that would have
been more use to you).
Haynes: Three spanner rating (intermediate).
Translation: Make sure you won't need your car for a couple of days
and that your AA cover includes Home Start.
Translation: But Novas are easy to maintain right... right? So you
think three Nova spanners has got to be like a 'regular car' two
spanner job.
Haynes: Four spanner rating.
Translation: You are seriously considering this aren't you, you pleb!
Haynes: Five spanner rating (expert).
Translation: OK - but don't expect us to ride it afterwards!!!
Translation #2: Don't ever carry your loved ones in it again and don't
mention it to your insurance company.
Haynes: Compress...
Translation: Squeeze with all your might, jump up and down on, swear
at, throw at the garage wall, then search for it in the dark corner of
the garage whilst muttering "curse word" repeatedly under your breath.
Haynes: Inspect...
Translation: Squint at really hard and pretend you know what you are
looking at, then declare in a loud knowing voice to your wife "Yep, as
I thought, it's going to need a new one"!
Haynes: Carefully...
Translation: You are about to cut yourself!
Haynes: Retaining nut...
Translation: Yes, that's it, that big spherical blob of rust.
Haynes: Get an assistant...
Translation: Prepare to humiliate yourself in front of someone you know.
Haynes: Refitting is the reverse sequence to removal.
Translation: But you swear in different places.
Haynes: Locate securing bolt.
Translation: Remember that worrying noise when you drove along the A38
last summer? That's where you'll find the securing bolt.
Haynes: Prise away plastic locating pegs...
Translation: Snap off...
Haynes: Remove drum retaining pin
Translation: Break every screwdriver in your box.
Haynes: Everyday toolkit
Translation: Ensure you have an RAC Card & Mobile Phone
Haynes: Apply moderate heat...
Translation: Placing your mouth near it and huffing isn't moderate heat.
Translation #2: Heat up until glowing red, if it still doesn't come
undone use a hacksaw.
Translation #3: Unless you have a blast furnace, don't bother. Clamp
with molegrips then beat repeatedly with hammer.
Haynes: Index
Translation: List of all the things in the book bar the thing you want to do!
Haynes: Remove oil filter using an oil filter chain wrench or length
of bicycle chain.
Translation: Stick a screwdriver through it and beat handle repeatedly
with a hammer.
Haynes: Grease well before refitting.
Translation: Spend an hour searching for your tub of grease before
chancing upon a bottle of washing-up liquid (dish soap). Wipe some
congealed washing up liquid from the dispenser nozzle and use that
since it's got a similar texture and will probably get you to Halfords
to buy some Castrol grease.
Haynes: See illustration for details
Translation: None of the illustrations notes will match the pictured
exploded, numbered parts. The unit illustrated is from a previous or
variant model. The actual location of the unit is never given.
Haynes: Top up fluids.
Translation: Drink 2 cans of beer and call out a mobile mechanic to
undo the damage.
*n
Haynes: Locate ...
Haynes: Pry...
Haynes: Undo...
Haynes: Ease ...
Haynes: Lightly...
spanner job.
Haynes: Compress...
Haynes: Inspect...
Haynes: Index
of bicycle chain.
with a hammer.
undo the damage.
*n
