It certainly is! I think I'll need some luck!
So, let's get stuck in! I think this and the M3 may well be proof that low mileage cars aren't always the be all and end all. The M3 is on around 100k more than this car now.
So, let's get started with the faults. This will scare a few, and TBH, it's almost scaring me! But I suppose it would be a 6 figure car now with back then, either complicated, or new technology.
HeadlightThe headlight did work when I bought the car, after I repaired the harness. It now no longer does, but the light cluster still works. To me, this sounds like either a ballast or an HID bulb issue. It did come with a spare ballast, and I have a spare ballast from the M3, which I'll cross reference ; it's working, but I bought another one when the HIDs played up on that. We'll see what switching things about does there.
Central LockingThe central locking doesn't work. The doors, the tailgate (which needs a manual override to work). Yet the lights flash when you operate the keyfob, and the keyless entry works! This did confuse me!
Further digging reveals that these use a Pneumatic & Vacuum operated pump assembly, called a PSE Pump for short. Yup, this 'modern' car still has vacuum central locking just like the old Mercs did. Except a few more details:
-It also actuates the locks inside the car
-The boot electronic button is operated via the PSE pump
-The boot also has a soft close function, which, you guessed it, is operated via the PSE pump.
Upon stripping down the pump, the news was not good. I'll share photos later, but the PCB was basically going green on one side, and the microprocessor had some tarnished legs on it. Not good.
If you google R230 PSE pump, you will see they are a common fault, and not a cheap thing to fix ; water damage is the most common issue, with it either damaging the board or the motor itself within the pump ; the impellors within the motor are rebuildable, which mine looks to have done already. I have as a result, sent mine away to get tested and see what the result is. Hopefully I can get away with it, but I am in the hands of the specialists now. It didn't stop me testing it with a power probe however. The motor still works, which is fortunate.
The RoofOddly, a dead PSE pump can stop the roof from working as well, since the boot separator switch feeds back to the PSE pump, which then allows the roof to work. A dead PSE pump, and I have no roof. It's the one reason I sent off the PSE pump, as I was tempted to live without the central locking. Sure enough, the dash comes up with a boot separator closure request when I try to open the roof.
The JudderThe minor judder was down to a shot track rod end, and rusty discs. The discs are cleaning up with me moving it about in the yard, so hopefully this should be fine.
The upper arms may need changing, which I also have courtesy of RockAuto, but it will require the ABC struts to be disconnected. Joy. ; There seem to be mixed reviews as to whether I need to bleed the ABC setup again via an ABC 'rodeo' test, or if I can get away with it. I still don't have an answer on that annoyingly. Worst case, I'll need to buy an Autel, or an iCarSoft Pro setup, which is annoying, but it would save on the Carly subscription I have, so that may not be too bad, and cheaper in the long run. The other way would be to buy STAR, or find someone who can lend me their machine. So far, I'm diagnosing the car with
RetroWarwicK's i980 reader, which has been invaluable.
No fuel? Ah, the Fuel GaugeThe fuel gauge is said to be down to the rear SAM (Signal Attenuation Module) failing, or a bad sender ; Merc seem to love them SAMs. The SAM in this car was replaced years ago, and the rear SAM is kicking out codes. One code, sure enough, is the resistance on the sender unit being too high. My plan is once the roof works, is to access the sender unit, and test it on the bench. Some do go rusty or varnish up ; this car did sit for 2 years remember. One telltale of the sender not working is the fact that the reserve light doesn't light up. Let's see how I get on there.
Boot struts not workingAs for the boot struts, that's now fixed. Courtesy of a delivery from a German outfit, I had some OE replacements in the form of Stabilus Lift-O-Mats.
However, I would need to hold the boot open somehow, and without a willing assistant, I'd need to improvise. With the Mercedes special tool in use, in the form of a broom handle, I soon had the boot propped up, ready to change the struts.
Soon enough, I have both changed in a jiffy, and a boot which was no longer trying to kill me! We'll see how long these last, or if I need to give them some blue pills to keep them up!
Yes, the list is big, but sulking away isn't going to fix it. I've rolled the dice, and am awaiting to see how I get along.
