Jul 12, 2024 22:02:49 GMT
This thread is going to follow my attempts at restoring an 1984 trabant 601 that has been neglected for quite a long while. It spent the last few years in the side of the road ant the weather has not been nice to it as rust took over the floor and paint started to flake. This being an "deluxe" model it has sensational options such as head rests , electric window washer fluid pump, a heated rear window and such. All features you would exepct even in the most basic trim for an 1984 car but thing in the GDR were a little... simpler.
Last Edit: Jul 12, 2024 22:50:15 GMT by 2stroke84
Jul 12, 2024 23:04:39 GMT
After so many years the left tires were surprisingly still on full pressure while the right ones where completly deflated. After a quick handpump up on the jackstand i decided to try to start the damn thing. Surpisingly it spun right up and after a few tries ot was able to run on whatever gas was left in the carb but that didn't last long as the fuel cock was gunked up to hell so i dragged it home on a flatbed.
Last Edit: Jul 12, 2024 23:05:35 GMT by 2stroke84
Jul 12, 2024 23:35:41 GMT
After bringing the corpse home i dissasambled the carb to clean it and unclog the fuel cock... in the process of which i found out that carb cleaner also dissolves the enamel of my bathtub With the carb back on and fresh fuel in the tank i managed to fire it up again and after some fiddling with the iddle screw i managed to get it to stop dying on me. Happy with my results i decided to take it for a test drive and see what other adjustments needed to be done, during witch my front bumper decided to take an early retirement plan and sheered the only bolt it was hanging on to. After parking it and fully taking the bumper off i decided to check and see why the power delivery was so jumpy when i noticed the back engine mount was broken (probably during loading/unloading on the flatbed) witch let the engine wobble back and forth yanking on the acceleration cable by itself.
Last Edit: Jul 13, 2024 21:10:54 GMT by 2stroke84
Welcome aboard. Good luck with your project.
Jul 13, 2024 20:58:38 GMT
For now i decided to leave the engine compartment alone and tend to the rust that plagues the car. Luckly about 15 years ago my dad decided to pour old engine oil in the chassis witch saved most of it. I can t say the same thing about the floor of the car though. It is full of rust and the trunk was an especially big issue. After struggling a bit to remoove the stripped and rusted screws on the quarter pannel it came off with a little pop of the antique glue breaking. After taking an angle grinder with a brush wheel to the floor it mostly just disintegrated leaving me with a big hole Luckly for me the chassis is not in a bad shape, the only structural piece rotted being the strengthening strip that follows the wheelwell
Jul 13, 2024 21:03:48 GMT
Excellent, I do love a good Trabant thread
Jul 29, 2024 21:41:52 GMT
I started work in the metal flange that holds the rear quarter pannel glued on, and cut a piece of it that was rotted and bent. After that i spent a few hours shaping a patch and getting the edges to alig just right with a dremmel, wich in the end was pointless After all that fiddling with the patch to get it perfect i put the pannel back on the car and left the project to sit for a few days.... during which it rained and some verry light surface rust got on the flange. Not a big deal, I just cleaned it with a wire brush wheel. Whati failed to take into account was the fact that the wire wheelalso shaved off a little bit of metal, making my perfect patch no longer perfect. I decided not to make another one and just use the one i made and fill the gap in while welding... well i'm not at all proud of how it came out as the pannel behind the stoplight is not completly straigh but i guess it holds?
Cool. I do like a Trabbie. I had to do the same kind of significant repairs in the boot of my last one. Good luck with it. 😃👍
