gezzard
Club RR Member Number: 69
Metro radiator unobtainiumgezzard
@gezzard
Club Retro Rides Member 69
Jun 20, 2024 11:24:09 GMT
So the fins on my rad are crumbling to dust, and the cars temp guage sits higher than halfway, so time for a new one I think. Only problem is finding one! ![](https://img.retro-rides.org/i/v/gezzard/f2317d1c5472.jpg) This is the rear of it which isn't as bad, now like I say finding one is near impossible, so my.question is, if I find one from a different car in a similar size 500x270ish would there be any issues? I found a few part numbers cross referenced here ![](https://img.retro-rides.org/i/v/gezzard/cc68e06aeec0.jpg) Original part number is ADU9098.
Jun 20, 2024 12:25:28 GMT
Can you not get yours rebuilt?
gezzard
@gezzard
Jun 20, 2024 12:55:49 GMT
Don't know, the end tanks are plastic, not sure if that would matter.
Jun 20, 2024 14:30:03 GMT
have you tried the apps like autodoc ?
jimi
Jun 20, 2024 16:13:52 GMT
Finished but might be worth contacting them, ad gives the dimensions and a load of cross reference numbers also a list of metro's it fits www.ebay.co.uk/itm/404645634940
Last Edit: Jun 20, 2024 16:18:26 GMT by jimi
Black is not a colour ! .... Its the absence of colour![](https://jlawson.co.uk/images/Jimisig04.jpg)
gezzard
@gezzard
Jun 20, 2024 16:24:20 GMT
I tried autodoc, and they have several listed, but all out of stock.
I've just messaged the eBay seller, so fingers crossed.
Thanks for the replies chaps.
Jun 20, 2024 18:56:13 GMT
is it a rover car or a austin car?
looks like a rover rad, or my r100 rad. You can get a mgf one to fit, and they arnt that expensive, just a bit of fiddling. I did it on mine.
gezzard
@gezzard
Jun 20, 2024 20:05:48 GMT
It's an Austin/Rover, this is it The MGF ones look similar, and there's one for a Maestro that looks like it too. Again, thanks for the replies.
If all else fails you could always get an aluminium one made. I had one done for my Sportshatch by a company in Cannock, it was fairly expensive but not much more than I was quoted for re-coring the original.
Jun 21, 2024 12:12:40 GMT
Try mini and metro center Warrington I sold them one about a month ago new 01925 444303
Jun 21, 2024 14:50:47 GMT
i tried that part number and it came up austin maxi ?
Jun 21, 2024 20:27:21 GMT
The Midas uses a Metro rad, and a lot of club members have switched to an MGF rad because it's easy to find and plentiful.
Mk1 Midases also used an Allegro rad, but I will be amazed if you find a usable one!
gezzard
@gezzard
Aug 28, 2024 17:49:50 GMT
So after a lot of looking, I found that MK 1 Fiesta radiators are roughly the same size, a small bit of altering the Metro plumbing and filing of the top metal bit and it fits. Self tapping screws were used to attach the existing fan, and an in-line fan sensor was plumbed into the top hose. New thermostat and sandwich plate gaskets and it's all back together with no leaks! MOT next....
