I'm reluctantly advertising my 1994 M reg Vw Corrado 2.0 16v, its in dragon green, 209k, Mot is until 20th November, ive owned this for the past year, its a daily driver and used all year round. Since ive owned it ive had an original steel sunroof put back in along with the sunroof cassette which all works as it should do, a previous owner had fitted a glass sunroof which had more of a curve and didn't match the roof line very well. A good Abs pump was sourced and fitted, new bottom arms , new discs and pads on the front, I also sourced another front seat as the bolsters were torn and worn but now like new again. Loads of other little bits n pieces . So now everything works as it should, even the rear spoiler goes up and down when its meant too and on the manual button too. 4 tyres are like new. Stainless steel Miltek exhaust sounds lovely and the 16v motor goes well. G60 leather steering wheel fitted, bit of rust starting on driverside rear arch, located in Dereham, Norfolk
Deposit accepted today, pending collection
