1993 E30 Touring 316i with 318is engine conversion
140k
MOT until Sept 2024
Full custom stainless steel exhaust system (new mounts and tucked up close to chassis)
Converted to Z3 power steering rack (2.8 turns lock to lock) with 4mm rack spacers
Z3 short shift gear linkage
New HSD e30 adjustable coilovers (5kg & 7kg)
Rear disc brakes
New front wishbones
Superpro offset m3 front wishbone lollipop bushes
Welded diff
Electric front windows
Electric mirrors
Full size matching spare wheel
Original 316i gearbox and differential (nice short ratios and oem fit)
E36 1.8l m42 engine with e30 specific m42 parts (intake manifold, exhaust manifold, sump, oil pick up, engine loom, ecu, MAF, airbox etc)
M52 coil on plug conversion kit
Brand new - Ford injectors, viscous fan, 318is radiator, water pump, oil, filter, gaskets, crank seal, clutch kit, spark plugs, fuel filter, fuel lines, gearbox and diff oils
Drivers door lock barrel isn't fitted but central locking works
Headlining is sagging at the back
Superficial rust on bottom of the doors, rear valance and bottoms of the front wings
The car is my daily and has been totally reliable. It's great on fuel and very fun to pedal. It's mechanically spot on but could do with a little tidying aesthetically. It's on the road, ready to be driven and enjoyed!
£4950 ONO
Price listed is with STOCK SEATS FITTED, not the recaros shown in the photos.
Located in Tiptree, Essex
![](https://scontent-lhr8-1.xx.fbcdn.net/v/t39.30808-6/429765912_10168874494925717_2175909435168300296_n.jpg?stp=dst-jpg_p720x720&_nc_cat=107&ccb=1-7&_nc_sid=369753&_nc_ohc=IxX9IR0jGmoAX_vITmB&_nc_ht=scontent-lhr8-1.xx&oh=00_AfB_tZXTfhTMKtbfs5_CnVI_iRp1V05lQbnoHrMttEgl7g&oe=65E3CDC7)
![](https://scontent-lhr6-2.xx.fbcdn.net/v/t39.30808-6/430081541_10168874494860717_2358724249284098119_n.jpg?stp=dst-jpg_p720x720&_nc_cat=100&ccb=1-7&_nc_sid=369753&_nc_ohc=vlIozpk0VsYAX9nYb0W&_nc_ht=scontent-lhr6-2.xx&oh=00_AfCJNwHw_dRLRaCDcDciUODWrpey1ZY4WzBvlIg8KmTPTw&oe=65E4F8DE)
![](https://scontent-lhr8-2.xx.fbcdn.net/v/t39.30808-6/430034749_10168874494830717_666349350149775590_n.jpg?stp=dst-jpg_p720x720&_nc_cat=106&ccb=1-7&_nc_sid=369753&_nc_ohc=GQlzoHqvnncAX94OCY3&_nc_ht=scontent-lhr8-2.xx&oh=00_AfBgCZ2_5NOKOCt_8KWPkyq5cX9IOy5_xYJsHcGz0G3fmw&oe=65E50E0E)
![](https://scontent-lhr6-1.xx.fbcdn.net/v/t39.30808-6/409022475_10168874494730717_819190800902313293_n.jpg?stp=dst-jpg_p720x720&_nc_cat=102&ccb=1-7&_nc_sid=369753&_nc_ohc=_vPsjKalPkwAX8zIK7P&_nc_ht=scontent-lhr6-1.xx&oh=00_AfCliqWxL9lLJDDZrGrtZLUtsBdh_-AtqVpPqw7HCBFtqw&oe=65E46EFD)
![](https://scontent-lhr6-2.xx.fbcdn.net/v/t39.30808-6/429649841_10168874494920717_4300269132882672809_n.jpg?stp=dst-jpg_s960x960&_nc_cat=105&ccb=1-7&_nc_sid=369753&_nc_ohc=AIBKOn9TbhAAX8azcRg&_nc_ht=scontent-lhr6-2.xx&oh=00_AfAANkUz_GcDMfvwMPqfbzZsESkV5pB68TqGozhW5R6KsQ&oe=65E4776A)
![](https://scontent-lhr6-2.xx.fbcdn.net/v/t39.30808-6/429678588_10168874494775717_2543540635084606261_n.jpg?stp=dst-jpg_p720x720&_nc_cat=100&ccb=1-7&_nc_sid=369753&_nc_ohc=5eOTE7NEWIYAX8f8nOF&_nc_ht=scontent-lhr6-2.xx&oh=00_AfDRZSA1aHHVsMGty0Fi3JnzXezlcoJvcR1t6rf5VPS8IA&oe=65E47252)
![](https://scontent-lhr6-1.xx.fbcdn.net/v/t39.30808-6/429591277_10168874494930717_8508634879001227879_n.jpg?stp=dst-jpg_p720x720&_nc_cat=109&ccb=1-7&_nc_sid=369753&_nc_ohc=l6Q_LHxXEvEAX_ei5wo&_nc_ht=scontent-lhr6-1.xx&oh=00_AfACAb77r-EG_ZAB5htnQ1Ze2Oma-7-LeyfAzR7_TRR-Tw&oe=65E45E32)
140k
MOT until Sept 2024
Rear disc brakes
New front wishbones
Welded diff
Electric mirrors
£4950 ONO
