Hello all,
I am the owner of a 1991Vauxhall midi 2.2 Diesel. Currently in need of quite a bit of work as it’s been left out in the weather and not driven much by the previous owner.
I was going round the brakes to check wear as they definitely in need of attention and came across a mangled brake adjustment lever, as well as what looks like an ineffective axle seal.
I have not been able to find a brake repair kit anywhere nor the lever on its own. Having similar trouble with the seals for the axle and the brake cylinder. Any help or advice on sourcing these would be appreciated.
Thank you x
Thank you x
