Jan 25, 2024 17:18:31 GMT
![](https://img.retro-rides.org/i/v/inkobl/208398d16b44.jpg) Hello Everybody, I'm actually rebuilding a Bedford Rascal and I would like to know if you know some way to improve the actual motor Suzuki F10A. Can I add a turbo Garrett 15 to have som extra power ? Which modification on the wheels do you suggest for security purpose ? Does I need to put better brakes with a turbo ? I've seen some guys doing a swap with a motor from moto bandits 1200, also with G16bb and K10a but it's like illegal and quite complicate. I just want to improve my truck a little bit Thks
Last Edit: Jan 26, 2024 15:58:51 GMT by inkobl
Jan 26, 2024 22:00:07 GMT
It depends on what it is possible to do wherever in the world you are, in the UK most things are possible, in Aus and NZ the same things will require getting it all certified and involving engineers.
Jan 29, 2024 11:07:47 GMT
I'm in Marseille / France
please find what are prerequisites to install a turbo at least :
TURBO GARRETT GT1549
Wastegate pour Garrett GT1549
Carburateur pour GT turbo / R11 turbo (carburateur soufflé / pas de aspiré trop dangereux)
Gas pump pour GT turbo
Malpassi pour Gt Turbo (régulateur de pression)
Last Edit: Jan 29, 2024 11:11:17 GMT by inkobl
