Hi guys does anyone have any experience of changing speedo faces from black to white i would like to change the heralds speedo i can buy a new one for £100 but there must be a cheaper way i can remember changing face colours was all the rage years back .
If you can get the faceplate out, scan it, reverse the colours with some basic image processing software, print a new one and trim it to fit?
If you can get the faceplate out, scan it, reverse the colours with some basic image processing software, print a new one and trim it to fit? that what i had in my head printed onto sticky vinyl i take it ??
79cord
Makes sense for older style face-lit gauges. I'm looking to do a newer cluster face but that's back-lit with clear/translucent numerals so they look dark until lit. Original white numerals wouldn't work with white face & covering them would block light (though some still offered stickers anyway), so would need to start from scratch with clear plastic cut to shape & have face colour cut from vinyl with numerals cut out, requiring a bit more work than simple image print which has stalled me.
Last Edit: Jan 4, 2024 20:46:33 GMT by 79cord
that what i had in my head printed onto sticky vinyl i take it ?? Anything suitable, really. I'd thought of doing it years ago for my car, in work I had a solid ink printer that I think would have done a decent job onto a decent paper stock which I could then just fix into place. It's important to get something that won't fade, so I'd expect that a lot of cheap inkjet printers wouldn't be up to it, though online printers could easily sort it onto whatever you want.
just sourced another speedo on ebay to pull apart
hopefully have a mate that can scan and print a new white face
bight another dash to mod too
Jan 14, 2024 15:31:06 GMT
i bought another speedo to pull apart so that will never work again 🤣🤣 may go for something one off rather than a copy of the standard speedo.
