Hi everyone,
I'm looking for any information you guys may have about swapping an MGB 1800 B series into an A40 Devon?
I don't have the origenal engine so don't have any reference points from that. I have sourced standard front engine mountings for an A40, however the 1800 front plate appears to be wider as the chassis mounts don't line up.
Before i start modifing mounts or front plates, Is there a bolt on solution to this ie a front plate that will fit the 1800 and take the A40 mounts?
I bought an A40 1200 front plate and that is no where close to fitting.
Any advice appreciated.
Thanks, Jim
Thanks, Jim
