Oct 11, 2023 10:05:20 GMT
Current set up on the T4 is
Leisure Battery with split charger >fusebox >disel heater, aux lighting and aux USB power.
Looking at a 100w rigid solar panel but I'm stuck /not confident on connecting the electrics.
Can I simply connect the charge controller to the leisure battery with the engine split charger system in situ or will it mess something up?
Any electrical experts/qualified bodgers input would be greatly appreciated. Paying someone to do this work just because of a lack of confidence doesn't feel right
Oct 11, 2023 12:12:30 GMT
yes you can connect a solar charge controller directly to the existing battery, controller you need depends on how many panels/amps you want to connect.
do you currently have a proper dc-dc charger or just a relay? you can get a renogy unit which does both, i.e a proper dc-dc charger and solar charge controller.
Oct 11, 2023 12:42:38 GMT
Thanks for the input welshpug. Just a split relay I belive.. There's no control unit or anything.
generallee
Oct 13, 2023 20:01:12 GMT
Definite non qualified bodger here... we connected our panel through a controller from Renology to the leisure battery like this.
Panel- RCD type trip thing- controller- big fuse- leisure battery.
Everything runs off the leisure battery as before, including a diesel heater, it works really well.
generallee
Oct 13, 2023 20:04:02 GMT
I should add, the controller works like a smart charger, hopefully keeping the battery in good condition.
Oct 20, 2023 15:07:16 GMT
Oct 20, 2023 15:08:41 GMT
Also, can be removed and charged and has a built in sine wave inverter!
generallee
Oct 20, 2023 20:18:26 GMT
Non qualified bodger I said! That looks a clever box of tricks, but would you have to spread the panels out when you want to use them, rather than just whacking them on the roof permanently and letting them do their thing?
Oct 21, 2023 19:05:06 GMT
Haha sorry!
My logic was that it can be easily charged up via the mains when we're out and about (nicking pubs and friends electric) also, it's less of a permanent fixture in the van when it's in full tat hauling mode. Also, it has a built in inverter so would be more cost effective than buying it all separately.
Looking in to the brand more, it seems to be a amazon sales focused, made in China, company. Something ideally I wouldn't usually go for politics aside.
I'm still in two minds really. Fixed solar i think would still be my preference. Its just the confidence of installing it / not wanting to drill holes in the roof etc.
Thought about those light bar magnets to hold the panel on then it'll just be one hole for the solar wiring
generallee
Oct 22, 2023 10:02:21 GMT
69 Plymouth Fury Convertible 75 Range Rover 2 door 82 Range Rover 4 door 84 Range Rover 4 door 78 Datsun 120Y 2 door 78 Datsun 620 Pickup 81 Datsun Urvan E23 85 Datsun Vanette van 02 Electric Citroen Berlingo 76 Honda C50 07 Land Rover 130 15 Nissan E-NV200
