May 12, 2023 21:57:40 GMT
A tad on the side of rare I know, but does anyone have a bright and clear pair of headlights suitable for an early model 2003 IS300? Mine are milky and do not polish. They otherwise work fine and the beam pattern is okay, but it would be nice to improve the appearance...
I'm located in the Peterborough area.
Last Edit: May 12, 2023 21:58:53 GMT by peanutsc
91 Citroen BX Diesel Estate (on the road) 85 Merc 200T Estate 83 Peugeot 205 (on the road) 61 Mini Convertible (on the road) 91 Ford Transit (on the road) 77 Mk1 Transit 60 Rover P4 100 (on the road) Various Moggies/Minis. Plus several others...
how aggressive did you go with the polishing attempt? I've had to go wet and dry on a few to cut back the worst.
They're a funny one - the plastic is discolouring all the way through, rather than just the surface - they are going opaque, but the beam pattern is good so gets through an MOT, they just look nasty. Tried the usual flat and polish to check.
