I got this a while back but its reached the point where I need a bigger one!
12inch swing
1 inch through bore
Mt2 tail stock
Screw cut gearbox
24inch centers
3 and 4 jaw chucks
Single phase power
Has a transport frame with wheels on
Needs a no volt switch and forward reverse Tumbler switch ideally fitting to it.
Currently is ran off the plug socket switch which is unsafe as it gets.
Can be delivered to a reasonable distance of chesterfield.
£350
12inch swing
1 inch through bore
Mt2 tail stock
Screw cut gearbox
24inch centers
3 and 4 jaw chucks
Single phase power
£350
