Mar 10, 2023 16:36:18 GMT |
Hi all,
Got a dgas carb on my commodore 2.5.
Idles nicely now but bogs down on throttle when driving. Any tips for setting up much appreciated.
Ritchie
Club RR Member Number: 12
Dgas carb gurus Ritchie
@ritchie
Club Retro Rides Member 12
Mar 10, 2023 18:11:42 GMT |
Could be the accelerator pump, if you take the air filter off and have a look in when you operate the throttle you should see it squirt in a jet of fuel. Also possible blocked mainjets, with the filter off give it a hard rev then put your hand over it to block the carb, the vacuum might clear an obstruction. Might have to pull them out of that doesn’t work.
Enbloc
Mar 11, 2023 12:28:32 GMT |
Does it bog immediately off idle?
If so, you may be idling on the transfer circuit.
