Feb 14, 2023 22:53:26 GMT
My old van used to like marking it's spot on the mono block, the van is gone but the large dirty oil stain is still here and I would like to get rid. So I'm looking for recommendations on what to use to remove the oil stains from the mono block. Thanks for all suggestions.
vulgalour
Club RR Member Number: 146
Cleaning mono block drivevulgalour
@vulgalour
Club Retro Rides Member 146
Feb 15, 2023 20:43:33 GMT
Lighter staining can be got rid of with laundry powder, a stiff yard brush, some water, and patience. Oven cleaner and a jetwash works on some monoblock, and bleaches or stains others so be careful if you consider that route.
norm75
Feb 22, 2023 18:29:40 GMT
Last Edit: Feb 22, 2023 18:31:56 GMT by norm75
jamesd1972
Club RR Member Number: 40
Cleaning mono block drivejamesd1972
@jamesd1972
Club Retro Rides Member 40
Feb 22, 2023 18:33:32 GMT
Coke can also work to lift / clean stains (peracetic acid) as can Citric Acid. Coke saved my bacon a bit with the attached garage and the gearbox oil incident. James
Feb 24, 2023 12:29:05 GMT
If they are the concrete block type paving laid on sand you can usually lift the blocks up and put them down the other way up.
