tigran
In rust we trust. Amen.
Club RR Member Number: 142
Techie Qtigran
@tigran
Club Retro Rides Member 142
Nov 30, 2007 23:14:18 GMT
Quick question dooodz. Just been pondering this for a bit - what can cause copious ammounts of reaaaally bright white smoke to billow out of an exhaust? Obvious answer is something getting into the firing process and burning off in there. That's fine, however no fluids are being burnt - no coolant loss, no oil loss. The only thing dissapearing is atf - and that's due to a leak somewhere.
The question relates to old boat anchor of a straight 6, namely in a rover p5.
Thoughts?
bstardchild
Club RR Member Number: 71
Techie Qbstardchild
@bstardchild
Club Retro Rides Member 71
Nov 30, 2007 23:18:41 GMT
Pretty certain on the fluid levels cos white smoke = water to me?
Davenger
It's only metal
Club RR Member Number: 140
Techie QDavenger
@dminifreak
Club Retro Rides Member 140
Nov 30, 2007 23:23:30 GMT
Yep, sounds like a serously shagged head gasket
Nov 30, 2007 23:26:04 GMT
and I was too nervous to say that - but agreed, white "smoke" = water
street
6.2 ft/lbs of talk
Nov 30, 2007 23:29:21 GMT
Does it get run regular? If not perhaps it's collecting water in the exhaust and bellowing it out in the form of steam when you get behind the wheel and give it some?
tigran
Techie Qtigran
@tigran
It got laid up when it started doing that - and yeah it was doing 100s of miles a week. The coolant is still brimmed - and i'm talking enough smoke to fill my street.
Ho hum i'll lob the head off and have a gander. Really hope it's something as simple as a head gasket.
Techie QBenzBoy
@benzboy
Really hope it's something as simple as a head gasket. Yeah I'd suspect steam too... and therefore HG failure. Compression tester could solve that little conundrum for ya!
What are the brakes like?? I had a car in once was sucking brake fluid through the MC seals and servo into the engine and burning it, chocking clouds of white smoke being the primary symptom. Also sounds a little like contaminated fuel, its surprising how little diesel mixed into petrol makes the car act like it just elected a new pope!
Techie QBenzBoy
@benzboy
its surprising how little diesel mixed into petrol makes the car act like it just elected a new pope! LOL ;D ;D ;D ;D
tigran
Techie Qtigran
@tigran
What are the brakes like?? I had a car in once was sucking brake fluid through the MC seals and servo into the engine and burning it, chocking clouds of white smoke being the primary symptom. Also sounds a little like contaminated fuel, its surprising how little diesel mixed into petrol makes the car act like it just elected a new pope! The brakes are icredibly shot, one of them seizing on the motorway and causing the blow out which caused the lay up of the car. Now that's an interesting route of investigation. Didn't, and wouldn't have even pondered to check the levels in relation to the smoke. Will do that asap, thanks a lot!
Last Edit: Dec 1, 2007 1:33:10 GMT by tigran
Techie Qdavemk1gti
@GUEST
the P6 also had a similar problem with servo sucking in brake fluid, take a look inside there deffo.
hum 'servo sucking' on reflection sounds like a bedroom sport.
its surprising how little diesel mixed into petrol makes the car act like it just elected a new pope! LOL ;D ;D ;D ;D It's that kind of humour that makes being here so much fun ;D
Peugeot 307sw - Suzuki SV650S - MX5.
