I have for sale a Nissan CA18det engine and garbox This was removed from my kit car.
The gear box was good when removed and comes with brand new quick shift lever
The engine is still in bits and needs to be reassembled and comes with a genuine Nissan workshop Manual.
The following is how it come
Rebored engine block with brand new Wosner forged pistons
A good checked crank shaft with new ACL bearings
New H beam steel con rods
Genuine new nissan oil pump
Genuine Nissan gasket set with sealent
Gates Raceing Timming belt
Pair of new vernier camshaft pulleys
Brand new light wieght flywheel
Brand new stage 2 clutch kit
It was Ballenced By Agra engineering in Dundee
There might be more new parts I am not sure.
It has a big wing sump which does not leak oil
There is a stainless steel tubular manifold with a T25 echange turbo ( under 300 miles )
The head need reasembled but its all there to build the engine
I have over 2K into this but will not ever use it. It will need to be collected, bearing in mind I am in the north east of Scotland. I would like £1,500 or a sensible offer
