Nov 22, 2022 20:43:56 GMT |
Back to the garage then. While working on the top, i’d also dug the bottom part level, ready for the base. The base was to be a big raft slab, all poured in one, I did kind of want to do the base myself, but common sense was drafted in and i tried to find a groundsworker to do it. I found a local guy who talked a good job, but after a few days it was evident he’d never done a big slab before and i lost confidence in him, so he went. Then found another local firm through a friends recommendation, these guys were more expensive but i saw their jobs, and it looked good. took them a while to start, and a 3 week job became about 4 months, which wasn’t great, but the quality of the work was outstanding. It took quite a while to get the steel, 7 weeks i think. Anyway The building inspector was happy with the steel and base and they Poured the slab in august. whilst waiting for the steel i dug in the power and water trenches (bottom right of slab) Only concrete but seeing the amount of work that went into it, it is a work of art! And amazing to be finely back up to ground level, and to have somewhere to park the cars rather than the mud
Last Edit: Nov 22, 2022 20:45:17 GMT by michael74
Nov 22, 2022 21:02:37 GMT |
Yay. Landy content added! Those gabion cages do look very good. I'm very Jealous of your Landy collection. I have coveted a forward control for years.
Nov 27, 2022 21:59:03 GMT |
great thread Michael. i can sympathise with the slab situation. i waited for months to get someone who was able to do mine.
@ CRX_IN_SCOTLAND
Nov 28, 2022 11:32:24 GMT |
I love threads like this. But I did think that the garage was going to be for all the Jaguar XJS parked next door until you showed the Land Rovers! Figured you'd just moved the cars while you built the garage.
Nov 28, 2022 19:48:46 GMT |
Yay. Landy content added! Those gabion cages do look very good. I'm very Jealous of your Landy collection. I have coveted a forward control for years. Thanks, Most people prefer the military version, the 101, but I've always wanted one of these, just need to get it back on the road. yes indeed #twincammy, but Sometimes you have to put up with the delays etc to get a decent job! I’m very pleased with the slab. Even the building inspector thought theyd done a very good job. on the suject of the jags next door, what you can see in the photos is the tip of the iceberg, he has many hidden away! i’m sure more than his wife is aware of!
Nov 28, 2022 21:24:52 GMT |
Michael74:
That is an impressive amount of work! Building on a slope presents different problems to solve, versus building on "flat" ground. The slab is looking great and I look forward to seeing the rest taking shape.
Regards, David
Dec 21, 2022 22:26:31 GMT |
Thanks for your interest, sorry its taken a while to update, but here we are, so, i had a floor, next step had to be the walls. Having put up a few garden walls, i thought i’d be better getting a brickie in. Found a local guy, who was brilliant, turned up when he said he would, and came back every day until he’d finished, a refreshing change from the groundworkers! Ordered some blocks etc, and the below went up very quickly.   I hired a genie material lift to do the lintel, and i helped the brickie get it up, and within 10 days or so, i had all the neighbours asking how many flats i was putting up..  The next challenge was steels, due to the length, it needed a ridge beam, and this in turn would need a support half way down. Although i had drawings i held off until the blocks were up, just in case. Very glad i did. The engineering drawings hadnt really properly considered the front doorway. I wanted a roller shutter to maximise space. If we’d built it by the drawings the roller shutter would have poked through the roof, not ideal! Did annoy me somewhat, as i’d been quite specific and paid a chunk of money, but anyway some hasty changes were made to the roofline, whilst the blocks were flying up. I then measured up, measured up again, and then once more, and sent my drawings off to the steel guys. ( yet another thing that has gone up a lot recently, You can see the central support lying fown in the middle. It wieghed anout 400kgs i think. Was a challenge getting it off the lorry with my mini digger, but it came off eventually, and once on the concrete floor, rolling them around was easy, i just used 4 short scaffold tubes and rolled them into position. Getting them up in the air would be a little trickier though! I hired 2 beam lifters, as these would need to go to nearly 3 meters, and the genie lifters don’t go that high. Found a willing friend to come and help( i owe him a few favours now) and cracked on. Amazingly it fitted perfectly, if a very close fit on the width, and i did have to trim the length slightly. But once it was up i was really starting to feel like it was moving on! Next would be the roof, but i’ll have to come back to that, thanks Mike.
