Jul 12, 2023 12:51:04 GMT
Modifying the Door Locks to compensate for increased thickness of composite door V X1/9 steel I settled on 2.2mm spacer Machined rings from L168 2014 Aluminum bar Drilled tapped catch piece M6 Machined top hat shoulder spacer, waiting on Torx screws I have removed the internal lock mechanism and the key barrel as race cars don’t have door locks 😀 Will machine black nylon blank for key barrel and bullnose plunger for the internal door lock Stripped and cleaned external door handles bit of satin black paint and reassemble
Jul 20, 2023 11:46:13 GMT
Tedious work door locks / hinges, however making progress Decided upon LB type rod end type hinges Using McGill Motorsports anti roll bar end links Cut to size M8 rod ends clevis pins (aid QD door) Door post face plate in 1/8” 4130 Female part of rod end hinge made 4130 rectangle box, cut down to match width of rod end width The doors need sanding down in couple areas as they are a little overlapping the door opening, but that’s ok as theirs room to make them fit as good as possible
Jul 21, 2023 13:01:21 GMT
Bit of apprehension of Uprights yesterday, I did get clarification this morning to put my mind at ease. WRC rears I cannot get until about November maybe December at worst case My front uprights from different company have been promised in 2 weeks but I won’t be surprised if that’s a month. Meanwhile I crack on with door side receiver hinge plate
Jul 22, 2023 13:27:21 GMT
I have been in mental quandary choosing Tyres and Wheels width and diameter From Pirelli P7 super Corsa Michelin TB5 retro tarmac Rally ranges, all big $$$ and limited availability Recently been looking at Nankang AR1 which are a DOT legal track tyre under half the price P7 / TB5, and readily available Reading and watching YouTube reviews that set my decision Down side is that the widest tyre I can get for the rear is 275/35-15 for 10.00 rim so no option of 295 315 however I believe model cutting edge tyre will negate the width discrepancy
Read an interesting test on BMW trying differently width Tyres looking at lap times OE was 225/255 front / rear They tried all tyres up to 295 width fastest lap was on 255/285 front / rear 295 rear was barely better than 255 So more can easily = less Finally on the O/D 15” definitely as doing gear ratio / top speed with the CR 6speed in 6th = 158mph much faster than I’m inclined to go however 6th will be good cruise gear on motorways etc.
Original Stratos Grp4 redline in 5th depending on gear sets used between 105-125mph not the std Busso V6 196mph with standard Alfa ratios You lose the whole spirit of a tribute car by having super tall gearing / lack luster acceleration
Shopped around and C Bradley Motorsports in N.Ireland has best to the door price on Minilites Placing my order for set of 8x15 et 12 grp4 10x15 et-20 grp4
Jul 24, 2023 13:09:02 GMT
Another 6 odd hours on Hinges Slotted the door post mounts, profiled base, TIG brazed the threaded pillars, marked up drivers side door receiver plate hole locations Deep curvature of door creates optical illusion, hinges are vertical 90 degrees 😀
Jul 24, 2023 18:17:22 GMT
Why tig brazed rather than tig welded? looking to be educated
Jul 25, 2023 13:30:54 GMT
Why tig brazed rather than tig welded? looking to be educated Welded on backside + it’s press fit, Braze adds larger fillet, less likely to distort plate as braze is at lower temperature
Jul 25, 2023 13:35:44 GMT
1 step forward 2 steps backwards Wasted my time mounting door to hinge plate Until I have the door fitting the openings close to perfect as possible Drivers door is too deep in the Sill opening Pass’ door is too long Tomorrow take some accurate measurements and out with the death wheel for some trimming so I can rough block sand to try get nice even gap Then go back to door / hinge mounting
Darkspeed
Club RR Member Number: 39
Jul 25, 2023 20:14:31 GMT
Out of interest - is that dimension the same both sides?
Out of interest - is that dimension the same both sides? Within 2mm, 135mm - 137mm central body in door post area has mimicked some repair damage, replicated in the Part, it’s small, can’t see both door shuts at same time so hard to spot John molds are obviously molds from molded panels + he got molds when he bought the original Litton, since has made his own where needed When mentioned to him his new wide front nose wheel arch flares where a bit off side to side he admitted so that all done by eye on his car It’s only a little, I can easily cut out the section then re bond it Having the jig platform is relatively easy to see discrepancies Re Doors the locks had location reference marks which I used as his (John) doors open close fine But they are actually a tiny bit higher than ideal to used Fiat strikers in the indent in body Now I am going to used a Stud Striker so I can achieve more vertical adjustment That means I have holes to fill 🙄 This morning I trimmed cut off some 3 mm bottom edge of the Drivers door fit looks extremely close now However on the Pass’ door John’s glass man has cut too much off, I will need to laminate a filler strip in later I’ll used Carbon Rod
Jul 29, 2023 15:17:21 GMT
Must have 40hrs in doors hinges locks Can’t be much more 🤞 Dispensed with X1/9 striker / catch due to not enough vertical adjustment ie I followed location marks in doors for lock position, needless to say they are are a little to high in the doors Here’s my own 2014 machined ally door striker pin Just needs top section fabricated to keep door accurately located 11.1mm pin o/d M10x1.5 thread
Aug 28, 2023 17:42:02 GMT
Temp thread diversion Got a bit tired on fiddling around with door locks and hinges, even though I’m really close, that and waiting on wheels and upright orders / delivery I needed to take a short break and rework my custom 1000cc SuperMoto bike for what I hope is Indian summer hoping for some nice weather in September October November ? Anyway for a temporary diversion here is what I’ve been up to Changing fuel tank, side rads to conventional front New mounts water tubes Bling bling Ti bolts in a few remaining places not already done + new ali’ petrol tank, working with poster board for templates to 1050 Ali’ sheet Evo Stratos back on track very soon
Aug 28, 2023 19:27:17 GMT
Not a fan of the coffin spoke wheels then? They're such a trademark of these cars, I'd have a hard time not using them. Or is it a size/fitment issue?
Not a fan of the coffin spoke wheels then? They're such a trademark of these cars, I'd have a hard time not using them. Or is it a size/fitment issue? It’s several reasons A. wheels are pricey can always update later B. I am going WRC Cosworth Hubs drive line ie 4x108 pcd this makes disc bells everything easy on parts availability and price point C. Tyres are issue too Pirelli Corsa Classic Limited supply and twice the price of Tyres That are actually better ie new design Nankang AR1’s To get further along money wise I have ordered 15x8 and 15x10 Minilites, these will be mounted with AR1’s this option saves me about £3000 V coffin and Pirelli option Checker Flag and other Stratos had used Minilites in the day so this is my cheaper and more efficient for me to make progress Later after the car is done then I will look at custom 3 piece wheel set up so I can have a cold / wet and warm dry wheel setup My rear body tail with round grp4 arches is done, I need to organize a box van to collect next week
Oooh, nice moto. Is that a (heavily modified) KTM 950 SM/SMR? Or is it a Super Enduro?
Aug 29, 2023 13:03:03 GMT
Oooh, nice moto. Is that a (heavily modified) KTM 950 SM/SMR? Or is it a Super Enduro? Totally custom build 990 SD engine backdated to carb’s modified frame, cut steering neck, ft & rr suspension from SR600 Vertemati Geometry as close as possible to the Vertemati 143kg 115 BHP
Aug 29, 2023 14:32:33 GMT
Wow, bet that's a handful. Got a 950SM myself, totally stock but on the look out for some Wings or Akra cans
Aug 29, 2023 15:14:17 GMT
[/img] 19 hours ago horrido said: Not a fan of the coffin spoke wheels then? They're such a trademark of these cars, I'd have a hard time not using them. Or is it a size/fitment issue? It’s several reasons A. wheels are pricey can always update later B. I am going WRC Cosworth Hubs drive line ie 4x108 pcd this makes disc bells everything easy on parts availability and price point C. Tyres are issue too Pirelli Corsa Classic Limited supply and twice the price of Tyres That are actually better ie new design Nankang AR1’s To get further along money wise I have ordered 15x8 and 15x10 Minilites, these will be mounted with AR1’s this option saves me about £3000 V coffin and Pirelli option Checker Flag and other Stratos had used Minilites in the day so this is my cheaper and more efficient for me to make progress Later after the car is done then I will look at custom 3 piece wheel set up so I can have a cold / wet and warm dry wheel setup My rear body tail with round grp4 arches is done, I need to organize a box van to collect next week [/quote] Ouch....3k quid is difference is indeed a persuasive arguement.
Darkspeed
Not only is it a £3K difference but due to the limited offset availability you have to design your suspension from the wheels back! At both ends of the car this can create problems but more so at the rear where the original Ferrari package was quite compact - Throw a modern transverse set up in the mix and it all gets a bit compromised with very short driveshafts and potential issues with CV angles . Original cars had a nice central diff and equal length shafts Modern iterations with current engines wanting to use the big neg offset wheels, but still not original offsets, start getting compromised on driveshafts. Conveniently painted red to show just how short the driveshaft can end up. Yellow car above with Supercharged Toyota 3.5L Exige derived motor and trans - Circa 400BHP - Which I understand is for sale at around £120K More competition orientated replicas went to more modern positive offsets to increase the driveshaft length to get more articulation.
