Hi there,
Does anyone know of a source for buying push-on stainless trim strips? The type which you push onto a metal edge with the little gripping springs inside?
Cheers.
Oct 11, 2022 17:08:28 GMT
Have you looked at bresco.com ? They do a range of trim clips.
fulvia1436
Finally started a thread for my Fulvia life
Club RR Member Number: 63
Push-on stainless trim stripsfulvia1436
@fulvia1436
Club Retro Rides Member 63
Have a look at part no FW062 from www.sheridanmarine.comIt's a very convincing alternative which doesn't damage paintwork, and it's cheap!
'59 Austin A40, '59 VW Beetle, '63 Mk1 Cortina, '57 Austin Gypsy, '68 Fiat 850 Coupe, '68 Alfa Duetto Spider, '72 Lancia Fulvia 1.3S, '73 Lancia 2000 Sedan ie., '72 Lancia 2000 Sedan, '67 Lancia Fulvia 1.3, '83 VW Passat GL5 Estate, '81 Volvo 245 Estate, '85 Lancia Thema 8V Turbo Estate, '99 Lancia Kappa 20V Turbo Estate, '00 VW Sharan VR6, '06 Fiat Multipla 1.9 JTD, '10 Fiat Multipla 1.9 JTD, '66 Lancia Fulvia 1.3
Oct 12, 2022 10:43:45 GMT
Have you looked at bresco.com ? They do a range of trim clips. I think you can probably get the clips from here but I'm looking for the whole piece.
Oct 12, 2022 10:45:35 GMT
Have a look at part no FW062 from www.sheridanmarine.comIt's a very convincing alternative which doesn't damage paintwork, and it's cheap! It can't be plastic. It's actually for some bathroom shelves which are great but require a bit of strengthening. So has to be stainless and has to be metal for the rigidity. A push-on stainless steel trim piece from an automotive application would be ideal... but where to find such an item!
fulvia1436
@fulvia1436
Oct 12, 2022 18:21:05 GMT
Have a look at part no FW062 from www.sheridanmarine.comIt's a very convincing alternative which doesn't damage paintwork, and it's cheap! It can't be plastic. It's actually for some bathroom shelves which are great but require a bit of strengthening. So has to be stainless and has to be metal for the rigidity. A push-on stainless steel trim piece from an automotive application would be ideal... but where to find such an item! ebd cars, Good luck in your search! Real ss trim was really only ever fitted to expensive, high end cars, like the Fulvia and other pre-Fiat Lancias. It is highly sought after, now. Most edge trim was either mild steel or brass (if you're lucky), and chrome plated.
I wouldn't mind chrome plated if the quality was reasonable. In a very wet environment less than stainless isn't a good idea but can be okay.
Slit some stainless tube and fit it over the edge?
Slit some stainless tube and fit it over the edge? Technically that could be done... but I'm the sort of person who would stare at it and agonise over it being wrong. A U-shape trim is going to be far better for this job. I like the shelves but they've been made from metal which is too thin. With heavy bottles of shampoo sitting on them they buckle.
