John Guest fittings for 22mm pipe. OK with nylon pipe or copper.
Bought a job lot to put a compressed air ring main in my garage, this is what I’ve got left over. They’ve all been used previously bar a few of the fittings listed. Two drop tees (water stops), 4 wall plate outlets, 6 straight couplers, 8 90deg bends, 2 stop ends, 4 x 3/4 bsp stubs, 2 x 1/2 bsp stubs, 1 x 3/4 BSP : 22mm female coupler, plenty of 22mm pipe clips. £75 for the fittings plus (say) £15 p&p.
I’ve also got 5 x 3m lengths of 22mm hard nylon pipe, a 2.4m length, and various offcuts. £40 for the pipes.
Shipping is easy enough for the fittings, not so easy for the pipes. Collection from West Berks unless you’re somewhere near where somewhere I’m going to!
