edk83
Exhaust is a frontline one I think, bought it from someone who upgraded to stainless although it's never been fitted. Wheels test fit, tyres are coming off in favour of some 60 profile rather than the 50
edk83
Dec 20, 2022 14:59:27 GMT
They do look cool with no windscreen  May have to steel that exhaust exit idea as well
Aeroscreens? Mine is homemade
Nuttier than squirrel sh...
edk83
Dec 21, 2022 14:21:14 GMT
Now that could work  Need to decide really if I plate over the windscreen mount holes
Dec 21, 2022 16:53:01 GMT
Because yours is a later model, like mine, there is an upstand on the doors which looks a bit odd without the screen. I used a scrap windscreen frame cut right down and capped to smooth the shape in front of the door.
edk83
Dec 22, 2022 17:06:59 GMT
Doors are now off and the rest of the dash, it's about ready to put on stands and strip the suspension and axle Next question is do I try to repair this dented sill panel or replace it, has a thin layer of filler already I think more bashing and investigation Might be better to replace it, I guess cut it off.  bottom is pretty dented in
edk83
Dec 22, 2022 17:12:50 GMT
Ahh you mean here, yes I could chop the frame i've took off as the glass is broken anyway The steel doors are pretty light weight anyway so might use them
Last Edit: Dec 22, 2022 17:14:34 GMT by edk83
Jan 11, 2023 19:44:55 GMT
Aeroscreens? Mine is homemade A chopped original screen similar to this would look pretty cool too.
Jan 12, 2023 12:19:38 GMT
I need to dig mine out, been 6 years since it last saw the road..
MK3 Capri 2.0, Starion Widebody, Midget 16v, E46 Coupe, E46 Touring 330
edk83
First time I've been under it last night, finally up on some tall stands. It's blue! Which is handy as the v5 states blue, will have to update that later.
edk83
No major horrors, no real rust at all that I can see, couple of small holes in the front of the floor pans that appear to be full of gravel, it's been used properly on track in the past. New front chassis legs ordered and on the lookout for a sill, let the chopping and midget modding begin!
Jan 19, 2023 12:50:36 GMT
Nice rear arch extensions. Couple of non standard rectangular holes in the bulkhead,
Jan 19, 2023 14:35:07 GMT
More parts collecting, 3J diff and a clutch release kit  Does this fit into the standard MG Midget axle, or are you fitting into a Ford one?
edk83
Jan 19, 2023 17:09:55 GMT
I've pulled the ally plates off that were riveted on, will make a new single part one so it'll only have holes that are used for something Do it full length so it covers the bonnet hinge recesses too
Last Edit: Jan 19, 2023 17:10:41 GMT by edk83
edk83
Jan 19, 2023 17:11:40 GMT
It's for a Midget A series axle, I have some Peter May en24 shatfs ready, test fitted the splines and they are correct
Jan 19, 2023 18:21:05 GMT
Very nice too. Where did you get hold of the LSD, if you don't mind me asking?
edk83
Jan 26, 2023 10:39:34 GMT
LSD I found for sale unused, its a 3J one Some chopping has begun
