Jun 26, 2022 12:30:52 GMT |
Looking for advice on converting my 83 Bedford CF camper to power steering. I’m hearing that a Corsa C steering column will be required. Has anyone done this conversion? What else will I need from the Corsa? I’m guessing the Bedford column will be cut and shut onto the Corsa one? Advice, photos, Bedford specific if possible but any advice gratefully received.
You need the column ECU for it and a Magic box to make the ECU think its still in a Corsa. I am quite handy but to be honest this bloke does kits that are first class, Ignore the web address he will do almost ant vehicle as a kit of fully fitted www.talbot-express-power-steering-conversions.co.uk
It will come in handy even if you never use it
I had a 73 Bedford CF, cant put my hand on any photos though. Had some great adventures with it
Got one of the kits from above on my Vw t25 All done in a couple of hours. Worth every penny.
I've done two myself, one on my Humber and one on a mates hot rod. I used Corsa C columns. If it's anything like the ones I've done you will need a lathe and welding facilities and if either of these are an issue then I would suggest paying is the best way forward. My installation is in this thread forum.retro-rides.org/thread/196225/1960-humber-hawk
Proton Jumbuck-deceased :-( 2005 Kia Sorento the parts hauling heap V8 Humber Hawk 1948 Standard12 pickup 1953 Pop build (wifey's BIVA build).
slipngripross
Owner of Slip&Grip Automotive Retro & Performance Car Sale& Events
Club RR Member Number: 149
Just had an Impreza rally car with this conversion and its quite good. Can be adjustable too.
a few other potential donors such as Prius, and I recently took a column out of a Nissan Note and have had that working by itself on the floor. I also want to put one in my CF so I'm following with interest. Would be even nicer to have a smaller steering wheel and better stalks too as the bedford switches are all pretty horrible.
Datman Datsun Parts www.datman.co.uk69 Plymouth Fury 75 Range Rover 78 Datsun 120Y 2 door 78 Datsun 620 Pickup 80 Bedford CF 81 Datsun Urvan E23 84 Datsun Urvan E23 camper 85 Datsun Vanette 00 Electric Berlingo x 3 76 Honda C50 15 Nissan E-NV200 16 Partner Tepee
