Any recommendations for a supplier of internal ZF bits? Second box has failed in ( I think ), the same way as the first. Shift valve has stuck tight in the valve block. No idea why this has happened and fairly sure it has happened again.
Had thought of making a brass or bronze one but heat might make it nip up?
