May 26, 2022 19:36:39 GMT
Hello everyone,
I bought my car 2 years ago and it had been stood for 30 years, now the car did run and drive fine before being parked up. (Car is ready for the road as its been renovated)
So ive had the (engine only) fully rebuilt and it runs lovely, ive had the gearbox oil changed for the recommended ATF, but the gearbox is difficult to select and crunches in both 2nd and 4th gear while driving. If you have the car stood still and idling, it goes into 2nd and 4th fine with no problems. I've got new clutch master and slave cylinder on the car, with it bled 100% fine.
So my understanding, is if the synchro was gone, it would crunch while idling as well as driving, wouldn't it?
Any ideas are much appreciated?
Thanks
Last Edit: May 26, 2022 19:37:52 GMT by jamezz666
May 26, 2022 20:39:18 GMT
It does sound like synchros, is it OK if you double the clutch?
One thing you might want to check first though is the external selector mechanism, the rubber bushes fall to pieces and it flaps all over the place, I have poly bushes in my tr7v8 which work well.
May 26, 2022 20:56:13 GMT
My first thought would be whether the clutch is disengaging fully, it would be worth checking all of the linkages and perhaps pressure bleeding it with an easy bleed or vacuum bleeder.
It would be unusual for two syncros to go at the same time and I would suggest clutch drag as a possible cause although if its not doing it when its stationary is a slight cause for concern, it might be that the clutch disengages enough for it to work when one part is stationary, does it go into reverse ok?
The other thing of course is that if you have never had it on the road before the box might be totally stuffed and thats why it came off the road, my MK2 Jag 3.8 was like that, it had no reverse gear as the reverse brake band in the auto box had disintegrated.
Best of luck with it, the SD1 is one of the cars that I always dream of owning.
May 26, 2022 21:32:03 GMT
It does sound like synchros, is it OK if you double the clutch? One thing you might want to check first though is the external selector mechanism, the rubber bushes fall to pieces and it flaps all over the place, I have poly bushes in my tr7v8 which work well. It's still the same even when you double clutch it and all the bushes have been changed on the selector mechanism. It's a real strange one, as i haven't experienced anything like this before.
May 26, 2022 21:37:06 GMT
My first thought would be whether the clutch is disengaging fully, it would be worth checking all of the linkages and perhaps pressure bleeding it with an easy bleed or vacuum bleeder. It would be unusual for two syncros to go at the same time and I would suggest clutch drag as a possible cause although if its not doing it when its stationary is a slight cause for concern, it might be that the clutch disengages enough for it to work when one part is stationary, does it go into reverse ok? The other thing of course is that if you have never had it on the road before the box might be totally stuffed and thats why it came off the road, my MK2 Jag 3.8 was like that, it had no reverse gear as the reverse brake band in the auto box had disintegrated. Best of luck with it, the SD1 is one of the cars that I always dream of owning. All of the linkages have been checked and the bushes have been changed. I'll have another go at bleeding it and see if it makes much difference. That's exactly what i thought, as it's more common for just 2nd on gearboxes to go. It will select 1st / 3rd / 5th and reverse fine. good thought on the clutch drag.. I'll have another play around with it tomorrow and see if i can spot anything, thanks for your input.
May 26, 2022 21:57:05 GMT
I would avoid ATF if I could. Redline MTF is good as is SMX (I used this). The ATF was a BL bodge to overcome cold graunching of the gears with the original specified oil. No thought given to box wear or longevity. Plenty on t'web about the issues (and yes, there those that have driven to the moon without a problem).
May 27, 2022 13:40:46 GMT
The other question that occurs to me is what ATF exactly do you have in the box? Back in the day ATF was ATF. These days there’s a lot more choice and viscosity and additive packages (slipperyness) vary.
2nd gear crunch is fairly typical of a hard used box as it sees plenty of action but 4th really not so much…..
If it was two gears on the same synchro hub I’d say you’d lost spring tension in the hub but these are on two different hubs shared with working gears…..
Nick
Last Edit: May 27, 2022 13:43:53 GMT by vitesseefi
May 29, 2022 18:35:02 GMT
Bit of an update...
so i pulled the gearstick gaiter up and i noticed there was a spilt in the clamp on the ball cup holder, so i removed that and welded the thing up as it was loose, but since clamping it all up the damn thing is even worse now!
So my problem of 2nd and 4th is there, but it's next to impossible to get 2nd or 4th.. almost as if the gearstick cant move far enough back, for the gearbox to properly go into them two gears?
Also it's near impossible to get into gears properly, as first and second are pretty much in the same position and if you pull the stick over to select 5th gear or reverse, it will go into 5th and reverse but the second you let go of the gearstick, it springs straight over to the centre where 3rd is, but still be in 5th or reverse? hopefully that makes sense.. if not, you know how if in neutral you pull a or push a gear stick left or right and it wants to spring back to the centre, well it does that but when it's in gear?
May 29, 2022 18:46:12 GMT
Are you sure the bushes on the remote are good and intact? That sounds a lot like the remote is moving.
May 29, 2022 19:29:43 GMT
Are you sure the bushes on the remote are good and intact? That sounds a lot like the remote is moving. yes they're new bushes. you could move the remote a little bit, say if you was to lever it with a good size screw drive or something like that.
May 29, 2022 22:01:17 GMT
Hi Is the pin through the swivel ball on the gearlever still there or broken, or the springs either side that the pin rests on to keep the lever in the 3 / 4 position? Item 26 in the pic. Colin
Last Edit: May 29, 2022 22:05:08 GMT by colnerov
Right i've had a look underneath and this is what i have found. The grub screw is locked in tight and that is not the problem, but i believe i've found the problem to all the play and troublesome getting gears. I cannot seem to solve the problem though. As seen in the diagram, you can see on the left hand side that there is a rod and i've marked the end in a blue circle showing the bushing. Mine has the bushing and selector rod pin installed, but the problem is as seen in my drawing on the right hand side of the diagram. There is a gap between both selectors and the selector rod pin, will not tighten up anymore? it's as if there should be something between the two of them to stop the movement. You will see i've attached three pictures i've taken, looking down at the nut attached to the selector rod pin, that goes through the gearbox gear selector and then beneath it the gearstick selector rod. This is the type of movement i'm experiencing and that is, as per photo 1. (without selecting any gears) i moved the gearstick to the far left, and you can see the gearbox selector rod is in the far left position with the nut facing to the left and as per what the arrow is pointing too, is the nylon bush beneath the gearbox selector rod, located in the gearstick selector rod. Picture number two, shows i've moved the gear stick to the centre position and note the gearbox selector rod/pin/nut are still facing the left position but the nylon bush beneath it which is located in the gearstick rod, is in the central position. picture three, shows the gearstick over to the far right position, note how the gearbox selector rod/pin/nut are still facing in the left position, but the nylon bush that the blue arrow is pointed to, shows the nylon bush beneath the gearbox selector rod, that is attached to the gearstick selector rod is now facing the right hand side. that is how much play there is, between both rods, but the selector rod pin, wont tighten up anymore. does the selector rod pin have a flat side? to help location ect. from underneath the car, you can push the gearstick shaft end up and down with about a 1/4" movement. so i'd say there is a 1/4" gap between both selecting rods, but what could be causing it? i can't access curse word all from underneath, unless i drop the gearbox out. hopefully it makes sense!
Last Edit: May 31, 2022 0:09:19 GMT by jamezz666
Darkspeed
Club RR Member Number: 39
May 31, 2022 13:34:23 GMT
Typically you can see the selector bushes under the bolts and washers each side of those pictures - and you say you have replaced all of them? That pin bolt is pretty manky You have welded up part 21 and that now bolts down to retain the stick correctly Bushes easy to see here as they are bright yellow poly Rewelded cup can also be see on that remote
May 31, 2022 15:25:11 GMT
Hi, The remote selector rod runs through two holes in webs underneath the remote casing, they could be either worn to excess or broken causing too much movement. Or the white Nylon bush in the remote selector shaft is worn. It's awhile since I've dealt with it but from memory the selector rod pin is parallel sided. Colin Edit: It's a bit of a fiddle but If you remove the gearbox mount, gearlever and propshaft letting the back of the gearbox down, you can remove the remote without taking the gearbox out entirely.
Last Edit: May 31, 2022 15:30:49 GMT by colnerov
May 31, 2022 17:20:40 GMT
Yes the pin is parallel, the selector rod just slides off of it, that one is amazingly rusty they are usually protected by oil leaking past the O ring on the selector shaft, they are easy enough to take off in the car as Darkspeed describes on a TR7 can't imagine the SDI is much different.
May 31, 2022 20:36:42 GMT
So i spent a few hours fiddling and i've found that it's the nylon bush that's worn, as the ball that sits in the centre of the bush, is nearly up and out of the bush about half way as seen in my drawing below marked in blue. So when you rock the stick left and right, you can see the end of the rod moving left and right, but not the actual gear selector rod coming from the box. Where can these nylon bushes be bought, as i contacted rimmerbros and a few landrover specialists and non of them supply the part anymore. I did find John Craddocks, but the part number didn't match the rover part number, but the nylon bush looks the same www.johncraddockltd.co.uk/frc5076-seat-for-gear-lever-lt7777s-and-lt85.htmlI only had 4 bush's, so i put two on the lower part as seen in Darkspeeds picture and i put two up top (not in front of the washers but on the other side). so i'm assuming then, that i should've received 6 bushes and not 4 when i purchased them?
Last Edit: May 31, 2022 20:37:59 GMT by jamezz666
May 31, 2022 21:07:46 GMT
It might be worth a look on the V8 forum, I seem to recall something about those on there although it was possibly a few years back. Sorry I can't offer anything more ( my lt77 had a Sherpa shifter on it, a whole different world of pain)
May 31, 2022 21:47:20 GMT
You might try robsport, they keep a lot of the more obscure parts for TR7's which use the same linkage.
Darkspeed
May 31, 2022 23:02:17 GMT
The complete assembly is mounted on 8 bushes each with a crush tube two bushes and a crush tube to each bolt that mounts the remote.
That nylon bush certainly looks like the right thing - I can dig a spare remote out of the shed in the morning and compare it if you like.
The complete assembly is mounted on 8 bushes each with a crush tube two bushes and a crush tube to each bolt that mounts the remote. That nylon bush certainly looks like the right thing - I can dig a spare remote out of the shed in the morning and compare it if you like. I'll get some more mounting bushes on order, as the others in which i only received 4 of, i had bought over a couple months ago. If you could get a spare remote out and have a look please, that would be great thank you. The only thing i can think of is it being wear on that nylon bush, that has caused the linkage to drop as low as it can (because of the centre part of the remote holding the linkage up) and leaving the centre ball exposed and a gap of 1/4 inch between the nylon bush and the flat spot of the gear selector if that makes sense. From what i could find on google, it looks as if the nylon bush edge/rim should be tight up against the gearbox selector. I've done a drawing that should be much clearer and make more sense, as i'm not too good with explaining these things!
Last Edit: Jun 1, 2022 12:59:48 GMT by jamezz666
