A-Series MD296SP scatter pattern camshaft
Spider drive for oil pump
£75
4x oversize pistons and connecting rods
73mm / 1360cc
Piston casting number 20659, pretty sure these are POWERMAX
£50
A+ 998 Mini / Metro gearbox including differential
Removed from a 1984 Mini Metro with ~30k miles
When removed the gearbox was functional but second gear syncro was showing signs of wear
3.44:1 differential
£50
Classic Mini 7.9" disc brake conversion using Mk2 Ford Fiesta calipers
Alternative to Cooper S 7.5" disc brakes using more modern single pot Ford calipers
Fits under most 10" wheels
MG Metro Turbo drive flanges and 8.4" discs turned down to 7.9" mounted on 8.4" hubs with drive shafts
Worked very well until removed and stored about 10 years ago so assume all parts need to be rebuilt or serviced before fitting
£100
£75
73mm / 1360cc
£50
3.44:1 differential
£50
£100
