Apr 24, 2022 18:08:55 GMT
Done a bit more over the weekend. Got all the ceiling closed off, then turned my attention to the section that forms the (soon to be) wall that separates the main garage from the bar. I figured it would be a good idea to make a section of this easily removable so it gives me access into or from the main garage without major trauma. So things like my motorcycles could be wheeled into the bar area in the winter or suchlike. With this in mind I hatched a plan This was given to me by a friend of my Mums about 25 yrs ago. I had it in my lounge a good while then when I decorated & changed the scheme it ended up in the garage just being used for shelving. It’s really well made from some sort of hard wood, but the dark brown just wasn’t doing it for me. So I gave it a quick sand off & gave it a couple of coats of magnolia. It still needs a couple more to cover completely but then I’m gonna rub the edges off a scuff it up here & there to give it a bit of a shabby chic look. It is approximately 4ft x 4ft & is easily moved so I’m going to use it as the removable wall. I didn’t want anything too heavy on top, so I’ve used a piece of the 3mm ply I had left from the ceiling & with just 4 screws that can be removed & then the bookcase slid away to give a 4ft wide full height opening. I have a plan with ply to make it more interesting, more on that later in the build. I also had a small win, in that my mate runs a kitchen fitting business, so when he took a kitchen out of a local bungalow to fit a new one I got this fridge for free. It’s immaculate inside (as was the property it came from tbh) So should do the job nicely
Apr 26, 2022 20:48:37 GMT
Apr 26, 2022 21:12:55 GMT
Next I turned my attention to the other gap to the side of the bookcase which needed closing off. I looked & thought perhaps a door would make the most sense, so then if I just want to go through to the garage I can, without going the whole way around to the front. The gap I needed to fill was approximately 33 inches. My Son had dropped off what had originally been his Daughters wooden playhouse that was worse for wear in places so he’d raked it apart & gone to the Council top with it. The guy wouldn’t let him leave it, said sheds aren’t allowed to be left. My lad said it’s a playhouse, he said ‘yeh that’s a small shed, you can’t leave it’!! It’s a complete joke, no wonder people fly tip. It’s basically wood, who knew. Anyway, he called me & said, I’m stuck, it’s in my truck & I ain’t got anywhere to take it. Bring it to me I say & I’ll burn it on my chimnea. Anyway I had just been too busy to process it so it was sat in a pile on my patio. I noticed a bit of one side & thought, that might work, pulled it out, it was 33 inches!! Winner winner & better still there were two sides the same. I fashioned them together & had this I found an old unused roof plate strap, presumably from when my garage extension was actually built, so I cut a couple of lengths off & used them as strengthening straps I then had this I clad it in pallet planks, then set about hanging it I’d had the huge strap hinges years & in fact they had just been laying off the side of the patio acting as weights to hold a board down which was basically just being used as a bird table. They are nice & rusty, so look perfect That was me done for the evening, the bolts through the hinges are just temporary as they were too long & not enough thread, so I just packed them for now until I get some proper bolts from work tomorrow
Last Edit: Apr 26, 2022 21:15:41 GMT by rattlecan
Apr 27, 2022 19:25:15 GMT
Only managed an hour or so this evening. Put the correct bolts in the door hinges & fired a latch to the door Took me ages to find a straight nail I could bend 🤣 Also scored another win, my Son is having his fence replaced & this is what was up (there is loads more to come) The planks are about 6 inch wide & quite thick, so that’s the flooring sorted then 😀
mrbig
West Midlands
Semi-professional Procrastinator
Apr 28, 2022 11:23:06 GMT
Looking forward to seeing this finished. I like the idea of being able to use for storage in the winter too!
1969 German Look Beetle - in progress
Apr 28, 2022 18:57:12 GMT
Got a few hours in there tonight & made a start on the flooring. I took the planks to my mates bodyshop & gave them just a quick rub over with a 40 grit on the DA The ones on the right, have been sanded & came up nice I did as much as I could but I’m now out of boards. This was just two of his fence panels & there are five more, so there is way more than I need, but the rest is still standing & is being taken down but not for about 10 - 14 days so it will have to wait until then
Apr 29, 2022 11:30:23 GMT
It was my birthday a few weeks back & my daughter bought me these for the bar My son got me these So by default the bar is now named With that in mind I found this My son made it at school for a project when he was 12 or 13 (he’s 33 now 🤦🏼♂️) It was made as a box to hold dvd’s, but it’s just been sat on a shelf in the garage since he left home. I gave the inside a paint & as the bar is now ‘Piston Broke’ I put a broken piston in there (why not?) it came out of my Yamaha RD350LC which I blew up in the Isle of Man a few yrs back He had written his name in the back corner (presumably so it didn’t get mixed up with another kids at school) I couldn’t bring myself to paint over it so I masked it off, so it’s still visible I have some led’s to go inside, should look cool
Last Edit: Apr 29, 2022 11:33:56 GMT by rattlecan
mrbig
West Midlands
Apr 29, 2022 12:07:57 GMT
Like it was meant to be! How about a little backlighting in the case now to make a real feature of it?
Apr 29, 2022 12:11:13 GMT
Like it was meant to be! How about a little backlighting in the case now to make a real feature of it? See last line of above 😀👍🏼
We took the rest of my son’s fence down on bank holiday Monday so I had another stack of floor boards I took them to my mates paint shop & gave them some 40 grit as per the others. I had a few hours at it this evening & pretty much got the floor finished apart from a couple of edges Try & look past the stuff all over the place & you get the idea
@hotwire Could this thread be moved to Garage Life so it's not lost amongst all else?
Last Edit: May 5, 2022 8:38:07 GMT by brachunky
I did wonder when I originally posted it whether to put it in garage life, but that all seemed to be sort of ‘proper’ garage & repair type stuff, which is why I put it here, but either way, suits me
May 29, 2022 17:37:31 GMT
Done a bit more this afternoon & clad around the doorway, all a bit fiddly around the light switches & door closure etc, but whatever, got to be done
May 31, 2022 19:18:39 GMT
Had another stint this evening after work
May 31, 2022 19:23:06 GMT
I am sooooo impressed and loving this space.
Your fencing seems to be of a decent wood, At one point it looked like oak, which certainly is out there.
I have oak fence posts stashed for future use.
I am sooooo impressed and loving this space. Your fencing seems to be of a decent wood, At one point it looked like oak, which certainly is out there. I have oak fence posts stashed for future use. Yeh too sure what it is, but it’s obviously good quality stuff, just based on how old it is & been out on all weathers for decades. You know what they say, ‘buy cheap, buy twice’ Buy quality & many yrs later some scrounging guy can use it for something else! I made the last bit up 🤣
I wanted just some kind of small sink, just to rinse glasses etc without having to go into the house every verse end, so here was my plan You will have noticed the smaller shelf was lower than the longer one. The reason for that was so it was a nice height for the sink. I got the hole cutter going. Take one zinc mop bucket Relieve the local caravan shop of a small sink plug & fit to said bucket Fit onto shelf & we have a sink with built in draining board 🤣
Garage (back bit of) Bar BuildHARDCORE
@hardcore
Club Retro Rides Member 190
@hotwire Could this thread be moved to Garage Life so it's not lost amongst all else? Done! This is ace, as is the rest of your garage
