Just a quick one. Checking the battery on my girlfriends car as it struggles to crank in the mornings/when its not been used for a bit. Before hooking up to the positive terminal I noticed it had a milky residue on the pole and connector. I didnt touch it as i'm guessing its some form of battery acid? or is it something else?
Positive milky stuff
Negative
Also this is the lowest the battery dropped to. I'm guessing with it being quite mild today it probably goes a little lower some mornings. I've started running the fuel pump a little before to help it a long. I noticed it dropped to about 11 something v when that kicked it before.
Negative
